Key won't turn and Wheel is locked in place? - Ford Truck Enthusiasts Forums
Old 01-18-2012, 10:42 AM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
Need some help I turn my steering wheel while the truck was off and in park and now I can't get the key to move and start the truck nor can I get the steering wheel to move. What have I done and how can I fix it?
Thanks
Old 01-18-2012, 10:57 AM
Coskid's Avatar
NVM I got it fixed thanks.
Old 01-21-2012, 03:22 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4 2004 xlt 5.4 is offline
2004 xlt 5.4 is starting off with a positive reputation.
What was the fix ??
Old 01-22-2012, 07:43 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Was probably in a "bind" against the lock.
Old 01-22-2012, 02:54 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Generally you 'go ape' on the steering wheel, left and right, while wiggling the key, and it'll pop free.
Here's how to drive the truck to a stop and avoid such problems and parking pawl damage in the trans; stop the truck with the service brake and wheels straight and hold the brake pedal firmly - holding the brake pedal, put the trans in Park - still holding the brake pedal, set the parking brake. Turn off ignition and release the service brake.
Okay, I realized that the complete process should be listed; Now to go, start the engine; depress the service brake and hold it - release the parking brake - put trans in gear - release service brake.
No yanking on the wheel, no yanking the shift lever stuck in Park, just smooth, easy operation doing things the right way. Try it for a refreshing change.
Old 01-22-2012, 03:33 PM
Coskid's Avatar
I locked the steering wheel. All I had to do was turn wheel as far as I could to the right (which was about 1/2") and the turn key forward without forcing anything and it unlocked.
Old 01-22-2012, 03:34 PM
Coskid's Avatar
I locked it by turning the wheel while the truck was off just trying to straighten out the front wheels some.
Old 01-22-2012, 08:30 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
Happens all the time. At least you didn't call AAA. I went to a few of those calls when I was starting out someone bought a new car now the key wont turn. The people were always embarassed when I explained to them what happend. Just the other day a lady went around the block and came straight back in her explorer because it had no power after I worked on it. The service advisor released the parking brake and told her to have a nice day.
2001 F-150 Ignition cylinder and Steering Wheel lock dilemma!! Tewkman 1997 - 2003 F150 2 11-23-2013 09:34 PM
Truck won't stop running ! Dr. Johnson 1994.5 - 1997 7.3L Power Stroke Diesel 7 11-15-2013 09:42 AM
00 7.3 F250 SD Diesel Key won't turn the ignition love2truck 1999 - 2003 7.3L Power Stroke Diesel 4 09-05-2013 09:05 PM
Shift lever felixc 1997 - 2003 F150 3 04-03-2007 03:26 PM
my steering wheele lock won't unlock forddytube 1987 - 1996 F150 & Larger F-Series Trucks 4 11-05-2003 12:21 PM
Tags
2006, 2008, escape, explorer, f150, ford, key, locked, series, start, steering, turn, van, wheel, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
