F to Bronco Fuel Tank Swap
Old 01-18-2012, 09:14 AM
5X5's Avatar
5X5
5X5 is offline
'88 F250 EFI 460 with the dual tanks. Want to swap the Bronco 38 gallon tank for the 2 tanks. I know I need the Bronco tank and electric pump. My Q is what to do for the straps, guage, and fuel line connections? Thanks
Old 01-18-2012, 10:15 AM
Edgethis's Avatar
Edgethis
Edgethis is offline
The guage wires you should be able to extend pretty easily. You can buy the straps for the Bronco fual tank. Then just get some lines bent for the tank to the filter. Someone whos done the swap should chime in. Just a heads up, the Bronco tank hangs down quite a bit lower then the F150 tank.
Old 01-18-2012, 10:40 AM
frederic's Avatar
frederic
frederic is offline
You use all the same bits for the bronco tank - fuel pump, sending unit and float, straps, et al.
Then you plug the front tank connections.
Old 01-18-2012, 10:50 AM
88dually's Avatar
88dually
88dually is offline
Get the same year bronc tank as truck, elec connector is slightly different between yrs. Lower straps will be custom, bronc isnt long enuff, F trucks arent long enuff
Old 01-18-2012, 11:04 AM
88dually's Avatar
88dually
88dually is offline
Bronco tanks for these years are either 25 or 33, u can get a custom made 45 for about $600. Lines will match upto F trucks
Old 03-14-2023, 11:14 AM
Youngoorah's Avatar
Youngoorah
Youngoorah is offline
so weird, im hearing the bronco straps would work.... now i dont know. Seems like they sell the whole bronco tank kit on jeff's bronco graveyard and was wondering if it comes with everything needed to do the mod.
Chris Guthro
09-01-2013 11:00 AM
nwebbe1079
01-09-2011 01:46 PM
boggerted
08-21-2010 03:56 PM
jskull351
12-08-2007 10:40 AM
hans99
10-17-2005 07:10 PM
Quick Reply: F to Bronco Fuel Tank Swap
