Dual zone heat
Dual zone heat
Well guys it was 40 below heading up to Fort Mcmurray yesterday morning. The 6.7 was running great but the heat on my side was poor and onthe pass side was hot. Played with the control but can't get good heat on the dr side. Warr is over. Any thoughts. Or time for a heater module
Thanks Don
Thanks Don
what happens if you turn off dual mode and just use single-zone climate control?
The last time I ever took apart a dual-zone climate control unit was when I was removing the entire heater box/evaporator core out of my 1998 BMW. There were three hoses that went in to the heater box (instead of the regular two) in the firewall. One for driver's side, one for passenger's side, one for return. Usually, it's one in and one out. I'm not sure how our trucks work, but I have to assume it's similar, so it's possible that hot coolant isn't circulating through one of the lines that feeds the driver's side.
But, to narrow down if it's a physical problem versus a control unit problem, put the climate control in single mode and see if you get good heat out of both side floor vents, which is where most of the heat is directed.
Thanks Don
Thanks Don
on
General warranty is 60,000km for a vehicle purchased in Canada (which is like 37,282 miles) and since Ft. Mac was mentioned I could very easily believe the high km.
Ummm as for the DATC problem I'm not sure 'cause I don't have that feature, it's still cold even when you override the thermostatic control and set to 'HI' on both sides? Temperature blend door not jammed or anything? Have to determine if it's a electronic issue or a mechanical issue...
Thanks Don
Thanks Don
Took it to the dealer and they had to pull the unit, i was told that they've had a couple 11's come back for that same issue.
I know they had to take apart the entire dash assembly incliding my center consel cause to get to it though.
2011s have an issue with the blend door... I newer one was made for 2012 and up... There is a TSB out on it.
I fixed my 2011 with a Forscan App, ran a diagnostic check and it fixed the HVAC as it moves everything around. Mine was so bad no heat or AC would come out of any of the vents.
