Bought another Ford, but not an I6 or PSD, need info
efrie, on your switch panel for the windows, if you go to the hardware store you can get a 2 part epoxy type stuff called plasti weld. You can useit to build up on the door panel a new area to drill holes and use the original screws to remount the switch panel. I have done it on both sides of the 95. It works great. I used masking tape on the door panel to make a bridge to poor the mix onto it. Then I just trimmed it and drilled new holes.
Well I looked at the door tag, trans says U.
So which transmission is that, and is it worth a crap? Also, I fixed the door handle with a big washer, still gonna form myself a bracket with some plastic weld stuff of JB weld for the electronic controls, because it's bothering the hell out of me. Every time I shut the door the controls move.
Other than that, truck is running great!
NW 150
11-09-2017 01:37 PM
PhL0aTeR
08-26-2011 10:13 PM
berry1234
15
08-18-2010 11:39 AM
shooer
04-10-2008 06:17 PM
