Super Duty 10.25" in a '97 F-250HD?
Has anybody measured these axles before. I've looked all over the net and haven't found good numbers and I never remember to check when I have a set of axles around. So, is there or isn't there a width difference between the OBS 10.25 and a SD 10.50? and how much is it?
OP, if you have both axles there can you measure them, FTF?
Spring seats are the same huh? My bad, I thought the super duty we're 1" wider on each side.
I thought the supers we're 4 bolt yokes as well but wasnt sure...anyway. Once you get it squared away Id be interested in a write up.
Thanks for that CJ, totally blanked on that part. I guess if you want the newer axle you're just going to have to change your bolt pattern to the newer one. As for the yoke, if its still a 10.25 you can swap pinions. I've decided to just buy a new ring and pinion set and a LSD to avoid opening up this can of worms. In the link the guy just went with the 8x170mm SD bolt pattern.
CJ06 is 100% correct-on this full floating rear axle the axle shaft is just the shaft-the wheel bolts to the hub assembly. IDK if the hubs would interchange or not-the outer bearings are the same part#, but the inners are different.
Not all SD have the flat flange, some have a yolk. Depends on the year.
Also the 99 SD axle have staggered calipers and 00+ have them in the rear
99+ axle are 8 on 170mm bolt pattern and You cannot just swap out hubs but you can machine out the holes to the 8 on 6.5" pattern and use special studs or drill 8 new holes on the 8 on 6.5" pattern
Florida_man
2017+ Super Duty
39
11-10-2018 09:06 AM
