Shifter Lever - Ford Truck Enthusiasts Forums
Shifter Lever
Old 01-17-2012, 07:37 PM
MAULMAUL's Avatar
MAULMAUL MAULMAUL is offline
MAULMAUL is gaining momentum as a positive member of FTE.
Shifter Lever
Does anyone know where I could get a billet aluminum shifter lever? It would be to replace the one on the column. It is kind of pitted, but I haven't found many choices for replacements. Thanks.
Old 01-17-2012, 09:14 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
For the column? Nobody makes a billet replacement. Have to go to an all aftermarket column to do that.
Otherwise it's Dennis Carpenter or LMC for a reproduction.
Josh
Old 01-17-2012, 09:29 PM
MAULMAUL's Avatar
Ouch! I guess that would be like buying a car because the air was old in the tires on the one I had. Dennis Carpenters here I come (again).
Old 01-17-2012, 10:09 PM
Bullitt390's Avatar
You know it couldn't hurt to take your old shift lever into a machine shop and ask... I've been surprised a couple times how willing and how fair priced a couple of my projects turned out.
Josh
Old 01-17-2012, 10:31 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Why not replate the original?
Old 01-17-2012, 10:45 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Might look on (or call up and ask) Bronco Graveyard, I know they have one for the floor-mounted shifters:
<img src="http://broncograveyard.com/images/catalog/NP435ALUMKNOB.JPG" width="300">
http://broncograveyard.com/bronco/i-...hift-****.html
Old 01-17-2012, 10:53 PM
Bullitt390's Avatar
4 Speed Billet Aluminum Shift ****
I believe the OP is asking about the entire column lever
Josh
Old 01-17-2012, 10:57 PM
ctubutis's Avatar
Oh, wow, the entire lever?
Sorry, nevermind (although you might call them and ask, IIRC they only fairly recently came out with this thing I listed above).
e40d, screwed up and need help Ceaumar 1987 - 1996 F150 & Larger F-Series Trucks 1 04-22-2016 10:54 AM
Column shifter pin saemetric 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-16-2015 07:48 PM
Shifter lever part number? tdpower 1999 - 2003 7.3L Power Stroke Diesel 20 02-24-2015 05:59 AM
1999 F-350 Auto Shifter Lever bronczilla 1999 to 2016 Super Duty 5 08-29-2014 08:16 AM
auto shifter broke 410 Highboy 1973 - 1979 F-100 & Larger F-Series Trucks 11 08-12-2011 05:54 PM
Tags
352, arm, billet, f100, ford, forged, gear, lever, pistons, ranger, shift
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
