2000 expedition electrical problems
i have a 2000 expedition and my reverse lights, cruise control, front blower motor,and my rear blower motor do not work, ive replaced fuse 5 and it keeps blowing, if i could just get pointed in the right direction or be given a solution it would be much appreciated. thank you!
If you don't shift to reverse, don't use the cruise control, don't use the front blower or the rear blower, does this fuse still blow?
You didn't indicate which model you have, if its 4X4, if it has air suspension, or an EATC heater, but here is what fuse 5 powers:
The DRLs
The Speed Control Servo
The DTR (Digital Tranny Range) sensor
The Function Selector Switch on the heater
The Blend Door Actuator
The EVO (Electronic Variable Orifice) Module
(variable power assist for the steering)
I'd suggest getting a wiring diagram so you can find an appropriate spot to disconnect all these items and see if the fuse still blows.
If it doesn't, then connect up one more of these items until the fuse blows.
Then you'll know what circuit to concentrate on.
BTW, has your Expy had the Cruise Control wiring recall fixed by the dealer to prevent a fire?
The DRLs
It is a 4x4 and it does not have air suspension. Is eatc electronic air temperature control? If so it does not have it. I have a repair manual for it but I don't think it has the wiring diagram for fuses. Is there a specific place I can look for that? And I just purchased it in June so I'm not sure, is that a huge risk?
Yes
Easiest way to check to see if your vehicle has had the cruise control wiring modification installed is to take your VIN to your friendly Ford dealer Service Department and they can run it through their OASIS system to see if there are any outstanding recalls on your vehicle.
Well, I don't know how huge the risk is, but I do remember that Ford was suggesting that vehicles be parked outside until the modification was performed.
(And some of the earlier modifications were recalled again for an 'improved' wiring harness modification.)
and thamkyou both for your help i should be able to get to it in the next couple days and ill get back on here.
