Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-17-2012, 06:25 PM
quiggs1404's Avatar
quiggs1404 quiggs1404 is offline
1959 Ford F-100
My Garage
quiggs1404 is starting off with a positive reputation.
223 Holley Carb help
I have a '59 with a 223 and the original 1bbl holley carburetor. It is in bad shape, it seems the fuel bowl was screwed on too tight by the p/o and the screw fittings have bent up and cracked the case of the carb. I have determined it needs to be replaced. Two questions. Does anyone know the model number of the holley carb that came on that year/that era of trucks? I know some of the early sixties 223's had a glass bowl on the 1bbl holleys and the one i have does not. Are they interchangable/what are some good options? I would like to stay reasonably close to original if possible. Thanks.
  #2 (permalink)
Old 01-17-2012, 06:55 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
1986 Ford F-350
85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.
william.a.vose
The glass bowl version was called a "Visiflow" by Holley. The bending and ultimate cracking of the main body is a common problem with these. The glass bowl and pot metal bowls are interchangeable provided you have all the parts for the glass bowl. Your original was probably a model 1920 as that's what my '58 F100 had on it.
__________________
Bill Vose (Old School Hot Rodder)
1986 F350 crew cab DRW 460ci EFI, E4OD, PMGR starter, 160 amp 3G alternator, 12X3 rear brakes, Traction lock 3.55
1995 Lincoln Continental (project car), 1994 Taurus LX (daily driver)
http://www.oldschoolhotrodder.com
"growing old is inevitable, growing up is optional"
  #3 (permalink)
Old 01-17-2012, 08:17 PM
spurredon's Avatar
spurredon spurredon is offline
Garage is empty, add now
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Here's one on Ebay, they are quite plentiful.
1950-60-70 FORD-MERCURY-RAT ROD HOLLEY 6R-931-B GLASS BOWL CARBURETOR | eBay
  #4 (permalink)
Old 01-17-2012, 11:59 PM
Tumblindyce's Avatar
Tumblindyce Tumblindyce is offline
Tumblindyce is starting off with a positive reputation.
The Holley on my Ford is 1904. I bought one of those glass bowl carbs from EBAY. While it is really cool, I think mine was originally intended for a car. There is no spark valve and no provision for putting a spark valve in it. The spark valve was made to work in conjunction with the vacuum advance on the distributor. The shop manual indicates that the "economy" carbureters didn't have spark valves. Also the jet was smaller than the one in my other carb...just saying you might not get the right application and your truck might not not run quite like it did before. You can get LOTS of info on these carbs on an International Scout site--I think it's called Binder Planet or something similar. Personally, I'm saving for a Clifford Performance intake and exhaust setup...can't wait to get rid of the 1904 and the 90 degree intake runners. Also, check your local carb shops. Mine had a couple of 1904's laying around the shop...
__________________
1960 F100 Custom Cab
  #5 (permalink)
Old 01-18-2012, 07:52 AM
1986 Ford F-350
william.a.vose
Yes, you definitely have the spark valve as these engines used a Holley "Loadamatic" distributor. Very likely the one on eBay is an industrial engine carburetor, those engines got a centrifugal advance distributor. I stand corrected on the Holley model, it's been 35 years since we sold the carburetor shop and close to that since I pulled the 223 out of my '58 and stuck a 312 and OD T85 in it.
__________________
Tags
1957, 223, 58, 6r, 6r931b, 931, b, carb, carberator, carburetor, f100, ford, holley, truck, visiflow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
