6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2010 F250 blowing white/blue smoke
Old 01-17-2012, 05:28 PM
MajekRFL21's Avatar
MajekRFL21
MajekRFL21 is offline
Ok guys, I am completely new to this forum and need help. I have a 2010 F250 that on 2 fight occasions has blown white/blue smoke out the tail pipes. This its my 2nd 6.4L and my 2008 never did that. I took it to the dealer and they can't find anything on the computer?
Any suggestions would be greatly appreciated..
Old 01-17-2012, 05:39 PM
redford's Avatar
redford
redford is offline
Received 1,561 Likes on 909 Posts
Sounds like maybe an overfuel condition.
Find another dealer and fast.
Old 01-17-2012, 05:50 PM
MajekRFL21's Avatar
MajekRFL21
My truck was full when that happened the second time. Don't recall on the first occasion.
Old 01-17-2012, 05:58 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Was it in regen when it happened? Ford claims it is "normal" IIRC, there is a thread in the 6.4L forum about it. I've had it happen once while in regen.
Old 01-17-2012, 06:00 PM
Sarge261's Avatar
Sarge261
Sarge261 is offline
When he says "over fuel condition" hes not talking about whats in the tank. Hes talking about somthing causing the engine to put more fuel in the cyinders which causes the smoke.
Heed the warning and find a new dealer to look at it, and quick.
Sarge
Old 01-17-2012, 06:39 PM
MajekRFL21's Avatar
MajekRFL21
Excuse the ignorance, but what type of things would cause an over fuel condition?
Old 01-17-2012, 07:18 PM
Sarge261's Avatar
Sarge261
Sarge261 is offline
Could be a bunch of different things, Leaking fuel injectors, PCM commanding the injectors on too long, faulty coolant temp sensor, there are lots of things that can cause it.
Sarge
Old 01-18-2012, 10:39 AM
MajekRFL21's Avatar
MajekRFL21
Doing it again
Ok, my truck started blowing white smoke again this morning. Immediately stopped and smelled the tail pipe and it does not smell like raw diesel. My thought is it smells more like coolant. Brought it to the other local dealer but what should I tell them to check for?
Old 01-18-2012, 11:10 AM
Sarge261's Avatar
Sarge261
Sarge261 is offline
Are the tail pipes sooty? I have read that they should be clean and if they show signs of soot the DPF is most likely cracked.
If it smells like coolant it could be a leaking egr cooler or head gaskets. I am not too familiar with the 6.4, but thats what happens when the egr cooler goes in a 6.0
Could a moderator move this to the 6.4 section so it gets more exposure and the op gets the help he needs?
Sarge
Old 01-18-2012, 11:48 AM
dkf's Avatar
dkf
dkf is offline
If the truck is stock it is going to go into regeneration cycles every now and then to clean the catalyst. There can smoke during the regen cycle. During the regen cycle basically a bunch of fuel is used to ramp up the EGT and burn off any soot or other crap in the DPF. I don't know if that is what you are experiencing or if you have another issue.
Tell the dealer what it was doing. The dealer will (well should) know what to check to diagnose the issue.
Post down in the 6.4l forum. There are a lot of guys down there that can help.
Old 01-18-2012, 12:07 PM
senix's Avatar
senix
senix is online now
Received 1,414 Likes on 1,009 Posts
Check all fluid levels, some white smoke during a regen is considered normal. I have had it once myself.
White smoke is an indication usually of burning coolant....if not in regen.
So what is your coolant doing? If you are loosing coolant then the egr valve and coolers need to be looked at.
Also what about your oil. Are you growing oil or loosing it? Since you indicate some blue ish smoke it could be that as a cause as well.
Also how far apart are the regens?
Old 01-18-2012, 01:36 PM
MajekRFL21's Avatar
MajekRFL21
Ok, when you talk about regen, I am assuming you are talking about the "Cleaning Exhaust" reading on the dash? The smoke is not coming out during that time.. And this is my 2nd 6.4L and my first never blew smoke out the tail pipes. However, my first truck did loose radiant coolant frequently and eventually cracked 2 radiators...
This truck is doing it on a regular basis and I don't believe it is normal...
I dropped it off at another dealer this morning and advised them of the responses I have received on this forum on what to check for...
Old 01-18-2012, 01:39 PM
senix's Avatar
senix
senix is online now
keep us posted.
Old 01-18-2012, 06:54 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.4L Powerstroke Diesel forum.
Old 01-19-2012, 05:34 AM
chi6488's Avatar
chi6488
chi6488 is offline
Good luck. If you take it into dealer and tell them white smoke during regen you are wasting your time b/c the tech will drive it out back and type in NORMAL and be done with your truck. If no codes are popping up this is what happens.
Maybe you might get a bored tech looking for something to do who will investigate it.
I s/w corporate about this yesterday and hopefully my complaint will open their eyes.
Quick Reply: 2010 F250 blowing white/blue smoke
