Installed battery backwards, truck wont start.
Old 01-17-2012, 04:55 PM
tdives's Avatar
tdives
tdives is offline
Ok bone headed move I know, installed battery backwards, tried to start, wouldnt lol, disconnected battery and connected right way, replaced 1 of the mega fuse's, checked fuses in power distro box, and under dash, still wont crank. any help much appreciated.
Bonehead
Old 01-18-2012, 12:22 AM
whitefordexplorer's Avatar
whitefordexplorer
whitefordexplorer is offline
check to see if your PCM is giving a signal to the OBDII connector under your dash... if not, new brain is in your near future (for your truck, and you)
Old 01-18-2012, 04:03 AM
tdives's Avatar
tdives
tdives is offline
A little more info 4.2 xlt, checked all the lights work, headlights, turn signals, dome, instrument cluster, connected a scan tool to obd connector no codes set, mil light is off, looking at electrical diagram power from switch goes through transmission safety switch then to starter motor relay, before energizing starter. any fuses to check i could have missed, when I said it wouldnt start, in doesn't even turn over. any thoughts? what about starter motor relay?
Old 01-18-2012, 06:35 AM
whitefordexplorer
couldnt hurt to check it...
Old 01-19-2012, 02:30 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Does the start relay on the firewall pull up by sound?
If yes the starter or it's cables are open.
If no, the start circuit from the ignition switch through the trans range selector to the start relay winding is open. Only fuse in this line is #21.
What can happen with the battery backwards is if the start circuit pulls up, the starter would try to run in reverse under a lockup conditon. It is a DC motor and is polarity sensitive.
The huge current could open an already poor cable.
There is not much to the circuit that a voltmeter check would not uncover aside from the starter cables being an issue.
The mega fuse has no part in the starting except as a convient connection point on the route between the alternator and the battery for charging.
Only possible reason the mega fuse would blow is from the reversed power from the battery shorting to ground through the alternator diodes.
Then you would need to replace the alternator if it does not charge after the motor cranks and runs.
Good luck.
Old 01-19-2012, 03:58 PM
cjtim's Avatar
cjtim
cjtim is offline
no more of this before working on any thing
Old 01-19-2012, 04:18 PM
fordiesel69's Avatar
fordiesel69
fordiesel69 is offline
When this happens, you typically blow a fuseable link. Usually everything survives, its finding the fuseable link that is the hard part.
Old 01-19-2012, 07:58 PM
tdives's Avatar
tdives
tdives is offline
Got to trouble shoot fuse 21, keeps blowing fuse, I did start truck today by jumping solenoid, alternator also bad now, probally blew diodes.
Old 01-19-2012, 08:43 PM
Bluegrass 7
From what you report, the start relay is still good.
This leaves the wire harness between the fuse block and the trans range switch and to the start relay with a short to ground.
I would remove the (usually tan/red wire) off the start relay and with fuse 21 out, check it to ground for the short.
If you see it grounded, look at the harness for overheating somewhere along it's length.
There may be other wires that overheated and caused the ground to occurr.
What has happened is the huge currrent that flowed from the battery did instant damge to wiring and the alternator.
The Mega fuse limited the current to it's distruction value. That is 12 volts times 175 amps = Two Thousand One Hundred watts of power and there is well three times that much in the battery.
If it were not for fuse 21 and the mega fuse the truck might have went up in flames.
That's why they were engineered into the circuits.
DEM INGEN EARS are pretty schmart!
Yesterday I couldn't spel ingineer, today I are one!
Kidding aside, there is a lot of power in that heavey black box with those big termnals (dats why there big).
Good luck.
Old 01-20-2012, 04:45 AM
tdives's Avatar
tdives
tdives is offline
Thanks everyone for all the help, will let you know what I find.
Old 01-20-2012, 04:00 PM
tdives's Avatar
tdives
tdives is offline
Where is the starter interrupt relay on this truck, I know its in RPO relay block, but where's that?
Old 01-21-2012, 05:23 PM
Bluegrass 7
I don't think you have one.
It would not be damaged by reverse polarity in any event.
The fuse 21 that is blowig is due to a short to ground.
The start interrupt relay is only it's winding being fed from that fuse and is not polarity sensitive.
If the relay were stuck in the operated position, it 'opens' (interrupts) the start chain only and not cause the fuse to blow.
In a Haynes manuel see page 12-17 for the start circuit to see all this.
Good luck.
Old 01-25-2012, 02:33 PM
tdives's Avatar
tdives
tdives is offline
Ok just a update found the trouble with the circuit, fixed, and she runs.
Thanks for all the help.
Old 01-25-2012, 03:38 PM
Bluegrass 7
Good to hear.
Quite a learning experience.
Good luck.
Old 01-25-2012, 04:29 PM
shorebird's Avatar
shorebird
shorebird is offline
Wait just a minute there partner!
That's not how it works.
You have a problem.
You come to us for ideas about how to fix YOUR SCREW-UP!
You get good troubleshooting advice.
You find the problem and fix it.
Truck is good to go.
You post thanks.
HERE'S WHERE YOU PAY FOR THE HELP!
TELL US PLEASE WHAT FIXED THE PROBLEM.
We live for information.
Littlejon
1997 - 2003 F150
03-21-2016 12:19 AM
BayouBoy827
1997 - 2003 F150
08-04-2011 11:16 PM
F-150_XL
03-20-2007 12:29 PM
86forddude
02-09-2005 11:56 PM
piercy
Modular V8 (4.6L, 5.4L)
09-29-2004 04:49 PM
Quick Reply: Installed battery backwards, truck wont start.
