F150 Curb weight - Ford Truck Enthusiasts Forums
F150 Curb weight
Old 01-17-2012, 05:33 PM
xjpilot's Avatar
xjpilot xjpilot is offline
xjpilot is gaining momentum as a positive member of FTE.xjpilot is gaining momentum as a positive member of FTE.
F150 Curb weight
Has anyone been to the scales with a single cab short bed f150, or know an accurate estimate of the weight? I'm putting together a list of specs for a reincarnation distributor, and I'm not really finding a number that I trust
Old 01-17-2012, 09:57 PM
dyingtolive's Avatar
dyingtolive dyingtolive is offline
dyingtolive is gaining momentum as a positive member of FTE.
My single cab, short bed '84 F-150, 300, 4x4, 4 speed weighs 4,950 lbs with me sitting in it, and I weigh about 200 lbs. And that's according to the scales at my local scrap yard.
Old 01-17-2012, 10:16 PM
xjpilot's Avatar
wow, thats a lot higher than I was expecting. I've read a bunch of posts around 4000 lbs or so.
Old 01-17-2012, 11:12 PM
86fordtruck's Avatar
86fordtruck 86fordtruck is offline
86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.
My door sticker says gross vehicle weight of 5500, for my 86 F150 4x2 SWB. I was also figuring on about 4000-4400 lbs at normal operating weight on the street. It'll be interesting to see what others chime in with. Maybe they can also weigh the front and rear axles so we can also compute the weight bias. How is the build coming, anyway?
Ron
Old 01-17-2012, 11:24 PM
xjpilot's Avatar
so far the build is slow, but thats about to turn around. I work 6 days a week and I'm at work for 10-12 hours a day, so it doesn't leave much time. I've decided to outsource the regear (they are at the shop now), so that is a good load off my shoulders. I'll start building the engine this weekend while I'm waiting for my lift components to get powdercoated. After that, I should have a rolling chassis by next week when I get the axles back, then I can start on the rocker panels, cab corners and roof. I will be finishing up at my company in another 3 months or so, so my goal is to have it running by then, since its in my bosses hanger at the moment
Old 01-17-2012, 11:41 PM
I hear ya'. I figure my build will take another year at least. I am doing it all by myself, so its a slow go. I am so looking forward to working with clean metal, though. Slowly, but surely.
Old 01-18-2012, 10:27 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
1984 F150 Custom short wheel base; 4 speed [SROD]; 4.9L with factory A/C = 3750#.
Old 01-18-2012, 12:36 PM
Good man, Dave,
What I started with is the same, only 2 years newer. So my calculations are in the ballpark. Any idea of the weight bias?
Ron
Old 01-19-2012, 02:39 PM
Thanks, Ron. Good to hear from you!
Old 01-22-2012, 08:07 PM
Terpfords's Avatar
Terpfords Terpfords is offline
Terpfords is starting off with a positive reputation.
I weighted mine at the quarry and it was right at 4000#, but I doubt it had been calibrated. 3750 would be awesome ! I've been chatting about T-5 installs and at that weight it would help.
So, why ask about weight bias?
Old 01-22-2012, 08:31 PM
Mostly curiosity. I've swapped out the I-6 for a 408 stroker, with aluminum heads and manifold, and then out back, deleted the leaf springs for a four link suspension. I was going to use air bags, but have decided to use coil-overs out back. I may eventually have to swap out the springs to better tailor the ride, but they're not expensive. Once completed, I'll take it down to the local performance shop and check it on their chassis dyno and get them to use their vehicle scales on it to get a weight on each wheel. I plan to use if for fun/weekend cruising, so it's not critical, but I am curious.
Ron
Max Towing weight? RedRaiderFan Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 1 09-13-2015 10:18 PM
1994 Fsuperduty question about weight and turbo Milwaukee1979F150 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 12-24-2013 09:32 AM
F250, F350, or F450? derherr65 Fifth Wheel & Gooseneck RV Towing 14 04-08-2013 07:41 AM
2011 or 2012 F250 Bumper Weights skscci 1999 to 2016 Super Duty 0 05-14-2012 10:41 AM
2wd snow, how much weight? mgdemarco General Automotive Discussion 21 01-02-2008 02:17 PM
Tags
150, 1982, 1984, 1985, 1986, 2006, 4x4, curb, f150, ford, normal, truck, vehicle, weight, weights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
