Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Missouri Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
  #1 (permalink)
Old 01-17-2012, 04:17 PM
chuck4907 chuck4907 is offline
Garage is empty, add now
chuck4907 is starting off with a positive reputation.
Head Gaskets
I'm new to this so bare with me, Please. I have a 05 f-250 that i suspect needs head gaskets, egr delete and the new ford oem replacement oil cooler. my question is this, Can i tackle the job myself or should i take it to the mechanic. I am mechaniclly inclined and i think i can do this, if it is straight to the point and nothing requires re-tuning and just bolts back together.
  #2 (permalink)
Old 01-17-2012, 04:45 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.
I don't recommend this for a novice wrench. If there's ANY doubt in your mind, don't do it. The Ford Modular engines (4.6, 5.4) have a problem with the heads. Where the spark plugs go in, the material is VERY thing and the spark plug holes strip out very easily. Torque specs and tighten sequence are critical on these heads as well. I also don't recommend EGR delete. They run just fine with them and you won't gain enough performance to warrant the effort. (You'll also have an engine light on constantly.) I think the oil cooler would be easy enough, however. For what it's worth, I've been turning wrenches for 30 years and I won't change spark plugs on any customer's modular engine. (And I just did an engine swap on a 5.4L)
__________________
Alan Fenstermaker
'79 F-150 300-6, 4 spd. 4x4
  #3 (permalink)
Old 01-17-2012, 05:12 PM
I have the 6.0 engine. i would buy a manual and stick to factory torque specs if i took on the job. i just don't have the money to put it in the shop. What to do?
  #4 (permalink)
Old 01-17-2012, 10:27 PM
cb_13's Avatar
cb_13 cb_13 is offline
2004 Ford F-150
cb_13 is gaining momentum as a positive member of FTE.
Look into the ARP stud kit for the heads as well. I would not recommend this as a good repair to try yourself but I have no idea of your mechanical knowledge.
  #5 (permalink)
Old 01-17-2012, 10:38 PM
jeff299's Avatar
jeff299 jeff299 is offline
jeff299 is starting off with a positive reputation.
The best way to do head gaskets on a 6.0 psd is to lift the body off. And I would also recommend arp head studs. It's a big job.
  #6 (permalink)
Old 01-18-2012, 05:56 AM
I've rebuilt a couple of small block Chevy engines, they weren't to difficult but they were not a 6.0 diesel. I once took three automatic trasmissions apart and made one good one out of the bunch. I've looked my truck over several times and I believe I can do it as long as it's strictly a job of taking it apart and putting it back together without some hidden things that have to be done. For instance, We bled the brakes on my wife's Infinity I30 and found out later that the ABS was supposed to been unplugged before being bled, now it's in the shop. I looked on the internet to be sure how to bleed them and never once read about that. There's so much BS out there on the web that makes it difficult to know the difference between the right and wrong ways to do things. Anyways, why should I pull the cab? I seen it done with the cab on. Is it because the heads have a hard time coming off the studs with the cab in the way or dose it just make the job easy? I have no way of removing the cab in my small shop.
  #7 (permalink)
Old 01-18-2012, 06:51 AM
There's no voodoo in taking apart the engine. Inside, they're still all the same. ....pistons, rods, crankshaft and so forth. I think you should be fine. Understand it's time consuming and complicated. Put the stud kit back in as you reassemble the engine and you'll be fine. The factory head bolts stretch under the cylinder pressure which is why the gaskets failed to begin with. The ARP studs help prevent that. If you're not sure about how things are going, take lots of pictures as you take it apart so you have a road map to put it back together.
__________________
Alan Fenstermaker
  #8 (permalink)
Old 01-18-2012, 07:49 AM
tcbofade's Avatar
tcbofade tcbofade is offline
1986 Ford F-150
tcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputation
Not to be discouraging, but if you haven't been in this thing before, I'd take it to the mechanic and pay the dollars.
For instance, I CAN replace the timing belt on my little car, and I HAVE done it before...but I won't...I'll drive it to the mechanic and pay HIM the dollars to save ME the frustration.
Just my two cents!
__________________
Join the Missouri Chapter!
If my Aunt had stones, she'd be my Uncle...
  #9 (permalink)
Old 01-18-2012, 08:20 AM
jeff299's Avatar
The reason I pull the can is because I can. Im a tech at a ford dealer and we lift the cab on the rack and leave the chassis on the ground. If you don't have a rack it's probably can't be done. You will need a engine hoist then to lift those heads off. There not light.
  #10 (permalink)
Old 01-18-2012, 09:13 AM
Just my two cents!
Yeah, but you need help from your daughter to change a light bulb!
I'm all for paying someone to avoid the insanity of doing the job, but if the truck's down and the funds aren't there, well then I guess it'll be worth it to have the truck back again. Just take your time and do it once.
As far as the hoist for the heads, they're not more than 150 pounds each. If you're feelin' froggy, I'd say you don't need it. Just climb up in the engine compartment and lift straight up. Don't try to lean over the truck and yank 'em off like that. That's a sure way to rearrange you man-parts.
__________________
Alan Fenstermaker
  #11 (permalink)
Old 01-18-2012, 10:34 AM
thanks for the info guys! again if i had the money, trust me it would go in the shop.
  #12 (permalink)
Old 01-18-2012, 04:04 PM
vloney vloney is offline
vloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to beholdvloney is a splendid one to behold
Quote:
I posted a step by step pictoral of it but its at another site.
__________________
ase master tech--fmc senior master tech 92 4x4 ranger 4.0
  #13 (permalink)
Old 01-18-2012, 07:51 PM
zstangkrewson's Avatar
zstangkrewson zstangkrewson is offline
zstangkrewson is starting off with a positive reputation.
definately not some for a novice to do, i agree with the boss on this one, take it to the shop, pay the dough and get a warranty in writing that covers any mechanical defects of the work done within so many miles or days... a good shop will cover its work in writing no questions asked
head gaskets are easy to replace. but the possibilities of other damages, cracks, valves, seals etc, require a trained eye to pick up, as for diesels, theres the whole gotta be perfect thing... id reccomend a shop.
sorry buddy, im sure this is last you wanted to hears... PEACE and good luck!
  #14 (permalink)
Old 01-18-2012, 07:57 PM
them heads cant be heavier than a 300-6 iron head.... get a haynes manual, if your going to do it yourself, take pictures, buy new head bolts, gaskets, gasket scraper, and anything else youll need, have a nice clean table ready to accept the parts in taken off order, this way you can look from left to right to see what you took off in sequence, then to replace, go backwards... simple yet easy to remember follow every line of the manual.
good luck.
  #15 (permalink)
Old 01-18-2012, 08:49 PM
I just spoke with my boss, and he plans to loan me the money to get it done. Thank God!
thanks for all the input guys, I really appreciate it
Tags
54, headgasket
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
