Fuel Filter Housing Leaking
The real question is where is the leak? Most of us have had to replace the o-rings on the drain valve at least once because they become brittle and begin cracking especially in colder weather.
Look around this site and try to find the parts for what you think is leaking:
Replacement O-rings for Ford Diesel Engines
Here is instructions for a complete rebuild:
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
Chances are you will only need to do this procedure:
Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
Take some time to look around Bob's site and you will learn a ton.
Bob (Guzzle) Replacement O-rings for Ford Diesel Engines was very firm about one of the issues of a leaking 'fuel bowl'.... people put the lid on too tight and it distorts the o-ring. Hence, slight leak, but no spray.
If you have not had a full fuel bowl overhaul, go ahead and do it as o-rings are a 'wear' item.
So You Think You Have a Fuel Leak - 7.3L Powerstroke - YouTube
Once you have identified your fuel leak, then you can fix it. Most likely its the drain valve.
Here is a video on rebuilding the fuel bowl. But if you want, you can do just the drain valve, which is doable with the fuel bowl in the truck.
How To: Fuel Bowl Rebuild - 7.3L Powerstroke - YouTube
60RatRod
11-25-2009 02:25 PM
speedrdr
32
03-14-2007 12:03 AM
