You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a problem with my fuel filter housing Leaking and I need to replace it. Should I go to the dealer and get a factory one or are there better ones out there? If so tell me where to get them.
The real question is where is the leak? Most of us have had to replace the o-rings on the drain valve at least once because they become brittle and begin cracking especially in colder weather.
Look around this site and try to find the parts for what you think is leaking:
I have a 2000 F250 4x4 with 265000 on it.
Chris
Bob (Guzzle) Replacement O-rings for Ford Diesel Engines was very firm about one of the issues of a leaking 'fuel bowl'.... people put the lid on too tight and it distorts the o-ring. Hence, slight leak, but no spray.
If you have not had a full fuel bowl overhaul, go ahead and do it as o-rings are a 'wear' item.
__________________ Brother Les
PAA Member #123
1991 F-150 inline 6
2001 F-250 7.3 Crewcab 4x4 BTS-Trans, 6.0 Trans Cooler, SuperChip, K&N Filter
