Photoshop Ideas
Defintely leave the fender emblems on. There is a hole behind them. I'm curious, do yours just say F150 and not have XL on the lower part?
Raising the front isn't permanent either. Its just a different pair of springs. You don't even need a spring compressor. This is actually just about as easy as lowering the rear in my opinion.
You can get Moog replacement springs that will do this for about 75 dollars.
I used to have the Superlift leveling coils on the front of mine along with some other modifications. I took all of it off and went back to stock. It looks fine, but I really think the level look is better. I'm thinking about doing this again and might use these. Moog CC822 or CC844. I'll have to find out which one.
I think once you have the front coil springs on, you'll dig it. I'm not one for lifting a 2wd either, but I don't really consider this a lift.
The Eddie Bauer trucks have that same badge. I really like the ones that just say F150 and nothing else. I always wanted to put them on my truck instead of the XLT ones. Too bad my truck as a small paint chip on one side right behind the XLT part of the badge.
Here is my 2wd with stock suspension on 31 10.50 tires. I don't think it looks silly at all.
To the best of my knowledge, all XL & XLT trucks had badges that said what they were. So am I correct in assuming that the PO changed it to an EB emblem?
