91 F-250 351w cam install difficulty
if this engine has never been apart this is a 6 hour teardown, minumum, i had mine apart in 3 (fresh and clean) and reaasembled in 4 , book time is 15 hours . i agree with the others, pull it, refresh, better heads, new bearings andpumps (water, oil ) cam and lifters. headers. then look into your gears. if you have doubts about the engine in its current state pull it and go thru it . my 96 with 192k had NO wear on the cylinder walls and rings , repalced the cam, main and rod bearings , and went back together .
also look on the front or rear pumpkin for a little metal tag. if its still there will show what axle ratio you have.
im just finishing up a cam swap. i pulled the motor.
new cam to me means new cam bearings and new lifters and new rocker springs, and either new lift rods or rocker shims. new valve stem seals
new cam bearings? means i tear down the block, hot tank, hone the cyl, new rings new main and rod bearings, new headgaskets, intake gaskets, new main seals, new oil pump, new water pump (depending on age, i reused mine but it only has 2000 miles on it), new timing chain... ect. i think im in around $500 for probably less (i didnt really take count), im putting on headers too, but im not including the price of that or exhuast (i bought my headers off craigslist for $100 and will do the exhuast myself)
do a leak down check on the heads to make sure that you dont have to do any head work
i almost did a complete rebuild... but i reused my pistons and rods
you have a 99% chance of breaking a few exhuast manifold bolts and maybe an intake bolt or two... unless you are the man at pulling broken bolts take it in to a shop to have them pulled... it you break a easyout/bolt out off inside the head along with the broken bolt they will charge you more...
with 35" tires you want either 4.56 or 4.88 my jeep(w/ built 318) has 37s and i run 4.56s on it (i geared to 4.56 when i had 35")
4.56 on 35" tires will give you around the same feel as 3.55
#28
TX92F150
04-28-2015 10:50 PM
m350
07-28-2010 04:58 PM
xpl0sive
07-31-2009 05:26 AM
pootscratch89
12-31-2006 10:28 AM
mustangsvo85
12-05-2006 08:32 PM
