2011 F250 3rd Gear Shifting Problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-16-2012, 11:53 PM
1991Brutus 1991Brutus is offline
1991Brutus is starting off with a positive reputation.
Hoping someone out there has seen this one. I have 28K on a 2011 6.7L Lariat. While accelerating normally (every day driving with no trailer or additional weght on truck), when in 3rd gear the RPMs increase as expected but then "decrease" a couple of 100 RPMs momentarily (see it on tach and hear it/feel it) and then increases again prior to shift into 4th. This only happens in 3rd gear. I have never seen this with a tranny before. It feels and sounds like this new tranny is "shifting" within the gear itself if that makes any sense. I had TSP 11-04-21 flash installed several months ago due to some hard shifting at lower gears and seemed to resolved problem. I have yet to take it in to dealer for this one because I wanted to research a bit before turning truck's fate over to service dept. Thanks.
<!-- / message -->
Old 01-17-2012, 06:53 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Sounds like the torque converter locking up (which it starts doing in 3rd).
Old 01-17-2012, 09:27 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Yes, it's the torque converter locking up. It's normal and working as designed.
Old 01-17-2012, 12:24 PM
Thanks
Thanks guys. Glad to know it is not an issue that needs to be addressed.
Old 01-24-2012, 12:22 PM
hntndawg hntndawg is offline
hntndawg is starting off with a positive reputation.
That is what I was hoping to find. Came searching for that exact same question.
1st, 2nd, no 3rd. '12 Duty Super Transit Connect 15 08-22-2016 01:43 AM
Does your truck do this?? Mikes150 2009 - 2014 F150 14 07-12-2015 12:11 AM
Transmission occasionally shifting strangely... seebeexee 1994.5 - 1997 7.3L Power Stroke Diesel 8 06-09-2013 10:32 PM
C4 shifting problems 79FordBlake Clutch, Transmission, Differential, Axle & Transfer Case 13 11-09-2011 06:47 PM
2011 shifting problem morrigj83 1999 to 2016 Super Duty 5 05-23-2011 12:45 PM
Tags
2000, 2011, 3rd, 67, f250, ford, gear, issues, late, problem, problems, shift, shifting, superduty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
