6.9 to 7.3 swap question. Help!!
I am looking to buy a 86 F350 4x4 crew cab in great shape, but the motor is shot and half taken apart and scattered. The same guy has a 92 f450 with a nearly new 7.3 crate motor in it. Said I can have the pair for 2 grand. Will the 7.3 just un bolt and drop right in the early truck? Or is there weird wiring and such that needs to be done? Also will the 6.9 automatic flywheel fit the 7.3? Please advise I gotta make this happen as quick as possible.
The 7.3 will bolt right in the 86, but the wiring harness is different. I'm not sure how much different, but I recall Dave S. saying he had toclip the plug ends and slilcing the two together. I'm not an auto guy, but I'm running a SMF conversion for a 7.3 on my 6.9. I would think the 6.9 flex plate would work on the 7.3.
I did the swap from 7.3 to 6.9. Your glow plug sustem will be different, but compatible. Spades lugs on the 6.9 bullet on the 7.3. Glow plugs will swap from engine to engine, best bet take whole glow plug wiring, relay and all from F450, better system, but you can just put your plugs in 7.3. Supposedly the balancer and flywheel balance different. Just make sure you use what came with engine (I have read that swapping both works also). If they are automatics the 92 probably had an E4OD. Different flex plate but flywheel should be samebolt pattern (yes auto uses flywheel). Use flex plate from original.
ok so it will need a 7.3 (auto) flex plate as its currently a 5 speed. So there really is nothing major as far as wiring etc. I have plans of just trying to adapt the whole setup over if its not to much work, along with adding the hydra boost brakes. I might as well rob whatever I can from the F450. So the injector pump wires and everything else should just cross over? Also the 6.9 has a ATS turbo setup, I asume the exhaust manifolds will work on 7.3? Sorry I am cramming all the questions in, but only have a few hours to make decision before the other guy gets it. I know the current owner so the deal is legit, I just dont want a nightmare project. But a motor R&R I can live with.
Im not sure what I will do with the 450. Its in good shape but only 2 wheel drive. If it was 4x4 I know exactly where the zf would be going.
In the meanwhile I still have to locate a c6 flex plate for a 7.3. Maybe I can trade a the flywheel and clutch for it or something. The 7.3 only has 6000 original miles as it was a crate engine just last year. So everything on it is new down to the belts. Kinda cool! I am excited to get it in there, but starting to stress on where I will find parts
All F450 are 4x4 trannies, but instead of a transfercase mounted, they have the parking brake mounted on it.
You can simply unbolt the park brake drum, and bolt on a transfer case, and bam, you got a 4x4 tranny
And you can't use the 92 pedals in the 86.
80-86 is one set of pedals, 87-91 is another, and 92-97 is another. Non will interchange.
You'll need a 82-86 pedals, (80-82 was a mechanical clutch) and will not work with hydraulic setup.
