DTC P0174 TOO LEAN LEFT BANK 1996 F-150 4.9L EFI - Ford Truck Enthusiasts Forums
Old 01-16-2012, 09:08 PM
joe.mcfadden joe.mcfadden is offline
joe.mcfadden is starting off with a positive reputation.
Hello All, I have a 1996 F-150 4.9L EFI 2WD 5 SPEED. Iím ready to give up here, four years of the infamous DTC P0174, I replaced all three O2 sensors, replaced EGR valve and mechanism near it, I even welded to repair holes in the skinny heat tubes for the egr sensor, cleaned the MAF, replaced both fuel pumps, replaced fuel filter, set timing, used starting fluid sprayed in all vacuum type areas safely while engine running, result was no vacuum leaks. Next Iím trying an additive with the hope that either an injector or carbon on the valve seats are causing the too lean DTC. Any reply would be greatly appreciated. Thanks.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Joe.<o></o>
Old 01-16-2012, 09:44 PM
Prof2113's Avatar
Prof2113 Prof2113 is offline
Prof2113 is starting off with a positive reputation.
How many miles are on it?
I have the same year and engine with 221,000 and just recently had to have the head rebuilt. Was chasing a miss, and it failed a leakdown test even though compression test was fine. It might not be the typical place to look, but if you think it might be carbon on the valves, it might be worth a shot. My exhaust seats in 2 and 3 were so worn, they sat 1/16' below the rest of the valves in the head.
Just purchased 2001 F150 has CODES 144k miles mhartiga 1997 - 2003 F150 3 05-27-2015 10:37 AM
F250 Mystery surge and miss retiredinstructor 6.0L Power Stroke Diesel 2 03-20-2012 05:30 PM
Pulling 12 codes on a 01 ford f150 please help boonehillbilly 3.8 & 4.2L V6 2 03-03-2012 07:24 AM
98 Ranger XLT, 2.5L - DTC P0171 brianc163 Ranger & B-Series 14 02-20-2011 04:38 PM
1996 F-150 4.9l Dtc P0171 And P0174 joe.mcfadden 1987 - 1996 F150 & Larger F-Series Trucks 2 05-09-2010 06:33 PM
Tags
150, 1996, 49, 49l, bank, code, dtc, efi, en, espaol, f150, lean, left, p0174, po174
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
