SG II Accuracy?
Well, it is cheap. That's the best thing I can say for it.
Second, the majority, if not all of these gauges were created by James DeLong of Linear Logic, the makers of the Scangauge II. He showed up on the Powerstroke Nation forums and just started making codes for the 6.0L.
So, the history of the EOT gauge.
This first one was the original. Found it wasn't as accurate as it should be.
TXD: 07E0221310
RXF: 046205130610
RXD: 3010
MTH: 000901F4FFD8
NAM: EOT
The second one here was better but he had made an error. And here is the link to the discussion on this EOT:
PowerStrokeNation : Ford Powerstroke Diesel Forum - View Single Post - Scangauge II FICM
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F
NAM: EOT
Which brings us to the final product for EOT. Which is now the one on their website:
TXD:07E0221310
RXF:046245130610
RXD:3010
MTH:00090005F060
EOT (This is the one I use now)
I also have a Torque APP that I have been using. I have compared the SGII readings for EOT and ECT with this app. They are almost identical. Of course, lifting my foot off the throttle while switching OBD2 plugs, my ECT would drop a couple degrees. (shouldn't be doing this while driving )
One time James provided, through a private e-mail provided by frenchy750 at this link: https://www.ford-trucks.com/forums/1...ml#post9753800 the Xgauge for ECT, so we could change f*WT to ECT. I have never used this one, but might do it to check the accuracy of it.
Engine Coolant Temperature (Degrees F)
TXD: 07E0221139
RXF: 046205110639
RXD: 3008
MTH: 000200010000
NAM: ECT
Yes, these Xgauges have been copied and pasted and moved so much that I have trouble remembering where and when things took place. But, almost every Xgauge I use was developed by James DeLong. He can be contacted at the Scangauge II home page: ScanGauge - Trip Computer + Digitial Gauges + ScanTools
James is a very helpful person. You have an issue or question, He is right there to help.
Sean
I agree 100% with this^^^^ Even a slighlty diff location could skew results
Did you splice into the OEM wiring Harness??
Where is your sender for Coolant temp at??? Give or Take a Couple inches of Hose May Not Cut it. I would almost be willing to Bet that Your SGII is Closer to the Actual Temp than your Standalone Gauge is
The OEM sender is right B4 the thermostate in the Front Cover Because this is the Coolants Hottest point and also where the Temp is controlled at
When I first got the SGII I had a 25* spread EOT vs ECT then I changed the Oil cooler and spread came Close together 6-8* summer and 4-6* winter at the steady 65 mph or whatever. So whatever its programmed the Numbers Moved in the right Direction
I say theres to many varibles to Just say the SGII is Sh** you would have to Pull and check EACH and every SENDER with a Mechanical Gauge to verify its accuricy in a Controlled condition.
These changes James Did was to get the EOT and ECT the same after a 12hour cold soak thats as Close as I can see getting the programming if there is a Skueed result as it heats up its more than Likely a Temp Sender
Here are 2 videos of my current temps using the SGII and Torque APP.
The first one is Torque APP. Note the ECT temp on this. It reads 41.0f. Funny the trans temp is fluctuating.
VID 20120122 150547 - YouTube
This second one is SGII. Note the f*WT does not read in a decimal point. So, I am assuming the SGII is probably near 41*, just a decimal lower.
VID 20120122 150710 - YouTube
This is about as close as I can read these temps with the tools I have.
My truck has been sitting since Thursday afternoon.
Me? I am pleased with both tools at this point. Does anyone think I should go deeper to make sure these are correct?
Sorry, wrote that last post when I was nearly asleep and not well versed! I believe the Scangauge is accurate as it reads from the OBD2, however the math used in the gauge may be wrong. After all, the fWt is really only an xgauge that's programmed from the factory if my assumption is correct.
Perhaps our trucks require a different code / math than other vehicles just like some of the other parameters the SG monitors? I will post up the codes I'm using for ECT and EOT when I get in my truck later tonight, I'd love for someone to try them out and give me feedback!
Wouldnt the coolant be hotter coming out of the coolant return line that comes out of the intake? (random thought...lol) im starting to think my stock ECT sensor is going out, the wires appear to be moist. I just entered the updated EOT and its right on with my EOT manual gauge. Now to get a new ECT sensor to see if that works
No Im right with you Sean
if that truck has been sitting 3-4 days you know every Fluid in that truck is the same Temp it has to be NO Question there
I would even BET your Windsheild wiper fluid is 40-41* LOL
Thats as close as you could get the SGII, AE,DD,EDGE any of them
If it was a Programming Error they(ECT,EOT,TFT) would be all over the Place at Diffrent Ambeint Temps.
But I feel pretty confident SGII is programmed right I mean 3 diffrent temp senders and after that long of a cold soak You KNOW there the same Temp they have to be
To me Stand alone Gauges are OK with Fuel Pressure Being the Best one a Person can add for a 6.0 The PCM dont use this one but as long as a person comes off the FP test Port then there Good but has to come from where it was designed to come from. If they come off the Fuel Filter Cap its not right and throw that number in the garbage IMO
But to add a Stand alone Lets Say ECT Gauge its Worthless its in a dIFFRENT SPOT so you cant really use it to check an OEM temp sender the PCM dont use it anyway
but Honestly if your Breaking down or have a Drivability Issue you have to see what the PCM is seeing Cuz the PCM is using those Numbers to Calibrate and Control the Truck so you could just about throw your stand alone gauge out the window cuz it has no bearing anyway
So if standalone gauges arent worth anything, why is my standalone ECT showing me 195ish give or take a couple degrees either way? and SGII is showing 180-188? Brand new ford t-stat and housing installed a month ago. And my EOTs match with the new updated SGII parameters.
Last edited by DevilDocTater; 01-22-2012 at 06:32 PM. Reason: Still cant type..lol
is it jumping fast from 180-188
When the reading is all over makes me think the sender
I mean I guess I shouldnt say stand alone is worthless but the PCM dont use its Number either
I just put in a new thermostat to and Im running 188-192 Being at 190* most of the time Motocraft as well
Your #s 180-188 ECT is what I was seeing with a Dura crap thermostat all over but this new MC is steady Lots better
Just curious myself . Got a sc ll for chrismas and installed the monday after . Start watching ECT & EOT. ECT temps. would only get to 179* . I had a delta of 20* -22* . Done a coolant flush with vc-9 & backflushed heater core. Installed new MC t-stat with housing. ECT only show 188* max. Now delta is 18*-20* . Possible SC ll problem?
#28
#29
I tried that they were within 1*-1 1/2* of each other. Truck sat for 2 days. Drove 40 miles on friday ECT 188* ECT 208* . ECT started out 188*, 190*, then back to 188* thats were it stayed.
#30
