tail lights stay on - Ford Truck Enthusiasts Forums
tail lights stay on
Old 01-16-2012, 09:24 PM
bent71 bent71 is offline
bent71 is starting off with a positive reputation.
tail lights stay on
08 F150 SXT. tail lights stay on weather pedal is pressed or not. i checked the switch on the pedal.looks ok. replaced the multi function switch. worked for bout a week. checked fuses 1 bad (run/accessory -wipers, instrument cluster, & audio for stx). right rear turn bulb is blown.
Old 01-17-2012, 10:42 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I am assuming you replaced the blown bulb? And by taillights I am assuming you mean brakelights. You have turn/brakelights and then you also have taillights/marker lights.
By chance are you running LED light bulbs?
Old 01-17-2012, 10:54 AM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
Do you have a trailer brake controller?
Old 01-23-2012, 11:05 PM
no brake controler and no leds.changed bulbs . turn signal on passager side still don't work. just found out the 3rd break light don't work at all.
Old 01-24-2012, 08:31 AM
thomabb's Avatar
Sounds like you have a bad spot in your wiring harness. has the wiring been modified for any reason?
Old 01-24-2012, 01:36 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Is the vehicle new to you? Sounds like the wiring was modified for previous owner if the truck is new to you. Maybe a remote start or ???? who knows.
Old 01-24-2012, 07:29 PM
I,ve had the truck bout 18 months found out later it was leased .ever get your truck back from a dealship & it was worst than what it was. things are going wronge that shouldn't.
Old 01-24-2012, 08:10 PM
Franklin2's Avatar
The wire for the third brakelight comes directly from the brake pedal switch. It's lightgreen(at least it was on the earlier trucks). I don't know if Autozone has diagrams for your year truck or not.
Old 01-24-2012, 08:50 PM
i'll check that out thnx
Old 01-24-2012, 08:58 PM
Quote:
there was a chip spliced into the MAF sensor. i took it out wire nut everything togetthere. Ford wants too much for a new. it should get replaced
Brake lights staying on. Need help 79schaefer 1999 to 2016 Super Duty 7 06-05-2015 10:25 PM
keep blowing brake light fuse LSO1123 1999 - 2003 7.3L Power Stroke Diesel 2 11-25-2011 08:27 PM
intermittent brake lights jmb924x4 Bronco II 6 03-29-2010 07:23 PM
Tail lights stay on whitewood 1987 - 1996 F150 & Larger F-Series Trucks 3 01-22-2010 08:42 PM
Brake light problem 1992 F150 1/2 ton ford jsharp921 1987 - 1996 F150 & Larger F-Series Trucks 4 11-12-2005 08:35 PM
Tags
2004, 250, f250, lights, lincoln, stay, tail, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
