another ford oil pressure question
i have a 1990 f-250 4x4 with a 351w . changed oil and filter put in aftermarket gauge . it has 55psi cold but when it gets to operating temp the oil pressure goes to 5 and below. when i give it some gas it does not go up at all in fact when it idles back down it gets lower and the lifters rattle . whats next heavier oil and lucas or rebuild ?
Thicker oil is just gonna be a band aid for a problem you don't need to mask. If the pump is dropping off that much, you need to replace the oil pump. Mine drops off a decent amount (at 188k miles), but it never drops below normal even with stock viscosity oil. When it does, it will get an oil pump.
Naa man, I'm sure the engine is plenty healthy...just needs an oil pump to keep it healthy. That's why I said "don't mask it with heavier oil". As for pulling the pan, its pretty straightforward I think...never done it on a V8 F-series of that era...so I can't say for certain but I wouldn't figure it'd be too hard.
If I'm fine with this many miles you definitely don't need a rebuild. Just take off the bolts and drop it. Shouldn't be any more than that.
