special socket needed to lower spare tire? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-16-2012, 04:39 PM
96_F250_Deezal 96_F250_Deezal is offline
96_F250_Deezal is gaining momentum as a positive member of FTE.96_F250_Deezal is gaining momentum as a positive member of FTE.
Question special socket needed to lower spare tire?
My 2006 F-250 didn't come with the spare tire tools, it appears there is some sort of special socket that is needed to lower the spare tire winch. how do I find out where to get the attachment?
Old 01-16-2012, 04:51 PM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is offline
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
Probably have to go to the dealer, or you can take out the part that takes the special socket so you could get a standard tire wrench to lower the tire.
Old 01-16-2012, 04:57 PM
Quote:
so far the dealer is clueless and it appears the the part that needs the special socket is part of the spare tire winch, so I would have to cut the cable to get the spare tire down and remove the winch. I was trying to avoid replacing the winch
Old 01-16-2012, 05:00 PM
smotrs's Avatar
smotrs smotrs is offline
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
I know you said it didn't come with the spare tire tools. But did you happen to looking within the glove box? They don't put the piece with the spare tire tools, they normally stick it within the glove box.
Old 01-16-2012, 05:07 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
You can remove the lock from the winch without dropping the spare but it is a bit of a treat. You need to pull the plastic piece that surrounds the lock straight back to remove it. Then you need to get in there with something and pull the lock out. I did it on mine and it was a bugger but definitely doable.
Old 01-16-2012, 05:09 PM
FarmingF250's Avatar
FarmingF250 FarmingF250 is offline
FarmingF250 has a good reputation on FTE.FarmingF250 has a good reputation on FTE.
Check glove box for the "key"
Even if you have the key it likely will be no good...won't engage the lock and you still won't get the tire down.
I had the key, didn't work.
You can also take and air hammer or chisel and cut notches in the "T" that is holding the tire, the "T" can be bent slightly to allow the tire to come off, but you will have to straighten it back out and weld it up to use it again (savings cutting and ruining the cable)
Check out some older threads on this issue, lots of photos!!!! The stupid key can be removed and tossed!
Old 01-16-2012, 05:13 PM
Madbasser Madbasser is offline
Madbasser is starting off with a positive reputation.
Use a 9/16 socket and long extension or a few put together. you need likt two feet. Beat in the 9/16 socket, then just lower the tire, Once the tire is down you can see the lock right there. Just pry it off with a flat screw driver then you will be able to just use the rie iron like normal.
yeah, its a retired border patrol truck. I bought it at auction, I got nothing with the truck, glove box was empty. rear seat and console were removed long ago.
Old 01-16-2012, 05:22 PM
Quote:
Yep.. did a search and there it is. I had searched before and didnt get the results I was looking for. I see how it comes apart now.
Old 01-16-2012, 05:27 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Most dealerships will have a set of the spare "keys" on a wire loop. When you come in, the can try each one to see which will fit, then order it for you.
Old 01-16-2012, 05:39 PM
I am happy to remove mine, it appears simple enough. I always hated those security sockets/lug nuts.
Old 01-16-2012, 05:44 PM
Hotpocket's Avatar
Hotpocket Hotpocket is offline
Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.
Quote:
this is what i did, they had about 15 keys
Old 01-16-2012, 06:05 PM
Old 01-17-2012, 10:30 AM
FirstSixOh's Avatar
FirstSixOh FirstSixOh is offline
FirstSixOh is starting off with a positive reputation.
If you are not using the spare tire lift lock and key, you are in danger of having your spare wheel and tire stolen. Anybody heard of cheap *******s who drive around at 2:00am until they find 4 trucks and steal all the spares? My last set of Pirelli OEM tires was $839. The spare tire lift key is there for a very good reason. Much easier and quieter to steal 4 spares than it is to jack the truck 4 times and remove 32 lug nuts. My dealer found the correct key from his little set and ordered me a new key #269 for $26. Works as it should.
New to me... 2000 F250 Crew Cab 4x4... No Key for spare tire... F0rdFre@K 1999 to 2016 Super Duty 3 09-24-2013 10:26 AM
Can't lower spare tire. IslandBlueV10 1999 to 2016 Super Duty 14 07-25-2012 12:21 AM
special key needed for spare tire winch chiefn10 1999 to 2016 Super Duty 19 01-31-2010 11:24 PM
missing spare removal rod? goatsniffer 1999 to 2016 Super Duty 7 01-04-2010 09:13 AM
Stuck Spare Tire UaVaj 1999 to 2016 Super Duty 10 04-02-2009 10:08 AM
Tags
150, 1999, 2008, 250, drop, expedition, f150, ford, hoist, lower, set, spare, tire, tool, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
