Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009+ F150
Sign in using an external account
Register Forgot Password?
2009+ F150 Discuss the 2009, 2010 and new 2011 Ford F150 SPONSORED BY:
  #31 (permalink)
Old 02-25-2012, 05:51 AM
shortride's Avatar
shortride shortride is offline
2010 Ford F-150
shortride is starting off with a positive reputation.
You can tow anything within the limits of the recommend capacities. People have been doing it for years before TBC was available.
__________________
2010 XLT Screw
2009 Harley Ultra Classic
Patriot Guard Rider
Vietnam Combat Veteran - 11F40
  #32 (permalink)
Old 02-25-2012, 09:27 AM
meborder's Avatar
meborder meborder is offline
Garage is empty, add now
meborder is gaining momentum as a positive member of FTE.meborder is gaining momentum as a positive member of FTE.
True, but those recommendations usually include the use of trailer brakes over a specified weight.
admittedly, the only reference in the 2011 manual is a rather obscure sentence on pg. 270 indicating that the brakes of the tow vehicle are designed to operate at the GVWR not the GCWR.
so technically speaking, if you take the weight of your truck, add all the cargo, and the weight of the trailer. if that number is less than your GVWR, then you wouldn't need trailer brakes. any vehicle combination weight over your GVWR, by this statement, requires trailer brakes.
even the manual for my 79 f350 includes a sentence requiring trailer brakes over 2000lbs towing.
i only comment because one could read the above comment to say that a truck with an 11,300lbs tow rating can safely tow that trailer without the use of trailer brakes, and that is not the case.
__________________
Mike ...
Work Horses:
2004 F250 SD SCREW; V10, Auto, 3.73's
2000 Explorer XLT; 5.0 V8, 4R70W, 3.73's
1979 F350 Trailer Special; 460, C6, 4.10's
  #33 (permalink)
Old 02-25-2012, 10:03 AM
kd0axs's Avatar
kd0axs kd0axs is offline
2005 Ford F-350
kd0axs has a good reputation on FTE.kd0axs has a good reputation on FTE.kd0axs has a good reputation on FTE.
Most states have laws regarding the use of trailer brakes. Here in MN, trailer brakes are required on any trailer over 3,000 lbs.
Check your local laws because these things are different in every state.
__________________
2005 F-350 SRW 4x4 Supercab, 3V 5.4, 5R110, 3.73 LS, Snow Plow Pkg, Camper Pkg, 285/65/18 Nitto Terra Grapplers
Previous Fords:
1985 F-250 4x4 351 Plow Truck, 1993 F-150 XL 4x4 300 I-6, 1995 F-150 XLT 4x4 300 I-6, 1998 Explorer XLT 5.0 AWD, 1983 Escort, 1991 Escort GT, 1989 Cougar
  #34 (permalink)
Old 02-25-2012, 10:15 AM
FoMoFun's Avatar
FoMoFun FoMoFun is offline
FoMoFun is starting off with a positive reputation.
Quote:
I have hauled campers, boats and trailers all my life and consider myself to be experienced hauler. but this would be the first time hauling a camper without the brake control.
Dumb idea...........you just spent how much on a rig and want to risk that, your family and others by driving w/o a brake controller on just a 100 mile trip? Spend the money (not much by the way) and hook up a controller. It's quite easy to do.
  #35 (permalink)
Old 02-26-2012, 07:54 PM
parker245's Avatar
parker245 parker245 is offline
parker245 is gaining momentum as a positive member of FTE.
I spent that last week either hauling a 16' Haulmark box trailer or my pop-up. Total cost for the controller and install was less than $110. Three times with the box trailer and once with the camper I needed them. Too many fools on the road around here than haven't a clue how to drive and will pull out in front of you no matter what you're driving.
Tags
2012, arizona, brake, brakes, camper, control, controller, ecoboost, f150, needed, pulling, rv, small, towing, trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
