1986 F350 351w heat riser gasket? - Ford Truck Enthusiasts Forums
Old 01-16-2012, 11:52 AM
Feenba Feenba is offline
Feenba is starting off with a positive reputation.
I can't seem to find any information regarding gaskets for the heat riser. I have a large exhaust leak coming from the heat riser and when I removed it to inspect it seems there are no gaskets? The one end of the heat riser is flat and has a steel on steel seal to the manifold, and the other end of the heat riser has a machined donut shape that clamps to the pipe with the two bolts. None of these had gaskets and when I cleaned up the surfaces on the mating parts and reassembled the leak still happens. Is there supposed to be gaskets on both ends? Thanks
Old 01-16-2012, 12:47 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Pictures would be cool, a lot of people here use "heat riser" to refer to many different components....
Old 01-16-2012, 01:39 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
The flat part has a gasket. I got a replacement at a Cole Muffler shop
Old 01-16-2012, 04:53 PM
I don't have any pictures, but it has a vacuum line running to it, with a butterfly valve inside. Bolts directly to the manifold on the drivers side. I took a pic from rockauto of what the new part looks like.
http://info.rockauto.com/getimage/ge...easons/126.jpg
It just seems odd there is metal to metal connections to seal the exhaust. I am used to seeing some kind of donut or gasket. If anyone has links or part numbers to the gasket I need, that would be awesome. Maybe there is some kind of gasket maker I can use?
Old 01-16-2012, 05:03 PM
ctubutis's Avatar
Yes, I thought it odd at first, too, the first time I ever saw a connection like that.
I can't comment on this specific application, but it wouldn't surprise me if that device was designed to not use any additional gaskets.
I tried looking in the parts book but wasn't sure what you were talking about (people use "heat riser" for a lot of things) but let me se if I can find anything useful in there......
Old 01-16-2012, 05:36 PM
ctubutis's Avatar
OK, found it in the FoMoCo 1980/89 Light Truck Parts Catalog, doesn't look like there are any gaskets installed with that device (so I would merely clean everything up good):
Old 01-16-2012, 05:47 PM
GLR's Avatar
GLR GLR is offline
Heat riser. Ford has been using that ball type connection for years. As far as the flat part gasket. 31512 might be the NAPA number. If I was closer (600 miles away) to my 86 I could come up with the Cole number.
Old 01-16-2012, 05:53 PM
GLR's Avatar
GLR GLR is offline
I might be wrong on that part number. If you go back to the Rock Auto cat. and check out exhaust manifold gaskets it shows a round and a flat with ears and bolt holes, I forget which one I used between the manifold and heat riser.
Old 01-16-2012, 06:06 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Is this it? Autozone part number 31512 or F14627
Old 01-16-2012, 06:08 PM
GLR's Avatar
GLR GLR is offline
That should work.
Old 08-13-2012, 09:11 AM
86bluetruck 86bluetruck is offline
86bluetruck is starting off with a positive reputation.
Heat Riser
When mine was leaking, it was not from the joint, but rather from the end of the butterfly shaft. there is a bushing that is supposed to be in there, it was GONE, and the exhaust was leaking out of the pivot hole. I had to replace the valve. That cured the leak!
1986 351w heat riser eriklane 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 07-05-2016 09:01 AM
Heat Riser fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 03-01-2015 10:22 PM
First Time Poster: Need Some Help ksdunlap07 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 07-29-2012 09:23 PM
Heat riser control ??? whisler 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 02-09-2012 05:43 PM
heat riser on 66 352 mdacton 1961 - 1966 F-100 & Larger F-Series Trucks 6 12-06-2010 07:16 AM
Tags
150, 1980, 1986, 2004, 351, donut, engine, exhaust, f350, ford, gasket, heat, parts, picture, riser, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
