1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Blinkers Broken
Old 01-16-2012, 10:38 AM
Brian Brandon's Avatar
Brian Brandon
Brian Brandon is offline
Blinkers Broken
Got a 03 ebExpedition not sure where to start on it. My blinkers are going CRAZY! they blink out of control and then stop working. I have checked the bulbs and sockets and all are functioning fine. the flashers, brake lights and everything else work fine just the blinkers are acting weird. Fuses are good and relay seems to work for everything else. Please Help I am going crazy with this thing and need it fixed yesterday.
Old 01-16-2012, 12:05 PM
alloro's Avatar
alloro
alloro is offline
Received 4,174 Likes on 2,419 Posts
Remove the top cover off the steering wheel. I'll bet the locking tab for the connector is broken and the connector is pulled 1/2 way out of the switch.
Old 05-05-2012, 09:15 AM
Brian Brandon
Cant fix this
checked the switch under the steering wheel and it seems fine no issue changed out relay and that didnt solve the problem so i started changing bulbs. That didnt help either. i am at a loss someone please help
Old 05-11-2012, 01:36 PM
RedHorse1's Avatar
RedHorse1
RedHorse1 is offline
The flasher relay may be the culprit, it's behind the panel below the steering wheel. 2 or 3 bolts on the lower edge will let you remove it (it's not 100% necessary to remove this panel to get to the relay but it lets you kind of see what you are after). The relay is to the left of the steering wheel and near the opt edge of that panel. You can reach up brom below and remove the relay (and replace with a new one). Mine had a plastic cover over the relay (to keep birds or something off, I guess) that has a push-to-release clip. If you can get the lights to blink (turn signals or emerg flasher) you can find it by feel, it makes the clicking noise. I got a replacement from the "zone" although they sold me the wrong one the first time. Once you know where it is it's not too hard to remove/replace without removing the panel.
Old 05-11-2012, 08:13 PM
John W. Fink's Avatar
John W. Fink
John W. Fink is offline
Is this the same location for a 2007 Expedition EL Limited?
Similar problem.
Thanks
Old 05-14-2012, 12:50 PM
RedHorse1's Avatar
RedHorse1
Similar problem.
Thanks
I don't know John but if you can get it to blink at all I'd suggest you put your hand up behind the dash and feel around. The sound will let you know the general area it's in and once you have a finger or two on it you should be able to feel the relays clicking.
cuttn4fun
03-21-2014 09:30 AM
Bearmo01
07-05-2010 09:12 PM
joeskyline06
03-05-2009 09:30 PM
PsD007.3
03-03-2009 10:10 AM
ojesuscares
1997 - 2003 F150
07-27-2004 12:06 AM
Quick Reply: Blinkers Broken
