6637 mod/K&N
Old 01-16-2012, 09:58 AM
1954oldred's Avatar
1954oldred
1954oldred is offline
6637 mod/K&N
I recently purchased a 2002 C/C SRW S/B 4x4...It has a K&N on it, I know I dont want the K&N (although it is clean and the turbo is not dusted) I bought a 6637 filter and plan to relace the K&N. Question being has anyone done this swap and if so did they use the K&N duct work? I will try it tonight to see, just wondering...I do not have the original duct work hence the concern.
Old 01-16-2012, 06:06 PM
1954oldred's Avatar
1954oldred
Got home and put the 6637 on the K&N duct work...it fit like a charm. Put the filter minder on and some nylons around the 6637 and all was good.
Until I shut the hood, it closes ok but is being held up a bit by the filter. I could pull the filter back out and cut away a bit of the stock filter box base... any other suggestions?
Old 01-16-2012, 06:22 PM
F350-6's Avatar
F350-6
F350-6 is offline
Make sure you've got a clamp on the filter to hold it to the K&N tube.
You're on the right track with the install. Your options are to either trim the box some or close the hood and put a dent in the filter.
Old 01-17-2012, 12:46 AM
4inchlovin's Avatar
4inchlovin
4inchlovin is offline
I use a 46637 wich is a wix instead of napa air filter (same filter pretty much) and my hood does not hit it. I should really measure it compared to a regular 6637
Old 01-17-2012, 09:52 PM
9905's Avatar
9905
9905 is offline
Did you ever get this resolved? I have the same K&N filter, and I just ordered a 6637 today and I was hoping it would work. If you could throw up a pic or two that would be awesome.
Thanks,
Hunter
Old 01-18-2012, 04:20 AM
1954oldred's Avatar
1954oldred
Thanks,
Hunter
I dont have any pics but I can tell you that cutting away a small amount of the stock base is all that is needed to ensure a good fit. It was a small amount of contact with the hood. You will like the improvement!
Old 01-18-2012, 07:09 AM
9905's Avatar
9905
9905 is offline
Thanks, that is EXACTLY what I wanted/needed to hear.
Hunter
papa tapout
15
03-12-2023 07:39 AM
superglide04
03-31-2010 01:55 PM
brownie83
16
02-09-2010 06:18 PM
schlichtemeier
04-13-2008 05:12 PM
dzjammer
04-14-2006 04:24 AM
Quick Reply: 6637 mod/K&N
