Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-15-2012, 11:06 PM
FossenRacing's Avatar
FossenRacing FossenRacing is offline
1977 Ford F-150
My Garage
FossenRacing is starting off with a positive reputation.
Cam thrust plate???
Was looking on the comp cam site and came across this.
COMP Cams: Thrust Plate & Bearings; Ford (390-428) 0.142"
I know what it is and where it goes but what is the point of getting one?
Is the factory one not adequate enough for use with one of thier cams?
Is there any point in buying one when installing a cam?
I am planning a build around a 1966 390 HP,GT or PI. Havent looked at the motor yet.
Guy wants 2000 for it complete rebuilt, It has gt heads and exhaust manifolds, adjustable rockers, lunati cam,edlebrock perf rpm, Aluminum tappet covers, all that and more. Can,t pass it up.
Hope i get there and its a 406 side oiler with crossbolt mains.
Has the manifolds that have slant bolt pattern which are moderately hard to come by from what i have read.
Will either save the heads,rockers,and manifolds for another project or sell them. should get 2000 for them easy and have a essentially free block with 10.5 to 1 compression. cant go wrong i dont think.
But back on track are these thrust plates for 700 horse mills or are they cost effective for 450 horse mill?
__________________
1978 Bronco,1977 F-150
1979 F-250 390-4v,6" lift(homemade),37 boggers,---(SOLD)
1992 F-150 Flareside 351 , 33 cooper radial sst
2003 F-350 King Ranch, Lovely 6.0l
  #2 (permalink)
Old 01-16-2012, 12:13 AM
maxtor's Avatar
maxtor maxtor is offline
Garage is empty, add now
maxtor is gaining momentum as a positive member of FTE.
When you blue print an engine for racing or just to make your engine run like a swiss watch, you should check your cam end play and it should be .005
Cam thrust plates get worn and when there is to much or to little end play, you can install the kit to bring the end play into tolerance.
The quick answer to your question is if your plate is worn, replace it with a good one or like the bronze plate from Blue Thunder for about $50.
BTW I blueprint every one of my engines, because they are all used for racing. Right now I have a 850hp 434 in my car and will be running it in March. It goes to the paint shop next week.
__________________
2012 F250 6.7 diesel
2007 Focus
1960 Falcon, 434CJ, 850 hp
Highly modified 240Z V8
C5 Corvette, supercharged
Tags
1986, 29, 50l, 93, cam, cyl, engine, ford, harley, plate, removal, retainer, sbf, thrust, tolerances
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
