Think I may need a wheel bearing, or a hub!?
So lately every time I have taken the 82 f150 out for a drive, going down the road, whenever I turn left, or hard right, I get a whirring sound coming from the front right corner. I also have a wobble that happens between 30-40 mph coming from the front right. My wheels are balanced, and my lug nuts are tight, I am thinking that it may need wheel bearings, or maybe something with the hub is messed up.
I know that you can jack up the wheel, grab it at 6 and 12 o'clock and shake it, to see if you need a bearing, but does that test apply to these 4wd trucks on the front? Haven't tried it yet, was about 10 degrees outside today, I really didn't feel like working on the truck at all!
How much of a hassle is it to change the inner and outer bearings on these trucks, if it turns out it needs em!?
Keyul
Keyul
Wheel bearings are relatively simple to change.From what you're describing,it sounds like it could be balljoints.You should buy a Chiltons Manual(Walmart sells them in Automotive Section)for 1976-1986FORD PICK-UPS AND BRONCO.Very informtive and detailed.Don't bother with Haynes manuals.Front hub 4x4 selector comes off,remove inner snap ring and the outer snap ring.You'll need a specialty 4 prong socket to remove the bearing retaining nut.AUTOZONE orADVANCE AUTO sells them.They're cheap.The front bearing can be accessed from the front.Remove the brake caliper and the rotor to access the rear bearing.you'll need new seals for the rear of the rotor.I would also check front steering linkage and suspension.It is pretty simple to replace frontend components yourself.Alot cheaper than a shop.You could do the whole front end for a few hundred dollars.The Death wobble is a sign that shouldn't be ignored.Good luck and get the CHILTONS BOOK it will help you save a ton of cash.
Lockholder
20
09-03-2017 07:34 AM
super 6.8
09-18-2016 11:59 AM
knecoli22
08-31-2008 02:48 PM
