Think I may need a wheel bearing, or a hub!? - Ford Truck Enthusiasts Forums
Old 01-15-2012, 10:29 PM
keyul's Avatar
keyul keyul is offline
keyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to all
So lately every time I have taken the 82 f150 out for a drive, going down the road, whenever I turn left, or hard right, I get a whirring sound coming from the front right corner. I also have a wobble that happens between 30-40 mph coming from the front right. My wheels are balanced, and my lug nuts are tight, I am thinking that it may need wheel bearings, or maybe something with the hub is messed up.
I know that you can jack up the wheel, grab it at 6 and 12 o'clock and shake it, to see if you need a bearing, but does that test apply to these 4wd trucks on the front? Haven't tried it yet, was about 10 degrees outside today, I really didn't feel like working on the truck at all!
How much of a hassle is it to change the inner and outer bearings on these trucks, if it turns out it needs em!?
Keyul
Old 01-16-2012, 01:35 PM
big vann big vann is offline
big vann is gaining momentum as a positive member of FTE.
Wheel bearings are relatively simple to change.From what you're describing,it sounds like it could be balljoints.You should buy a Chiltons Manual(Walmart sells them in Automotive Section)for 1976-1986FORD PICK-UPS AND BRONCO.Very informtive and detailed.Don't bother with Haynes manuals.Front hub 4x4 selector comes off,remove inner snap ring and the outer snap ring.You'll need a specialty 4 prong socket to remove the bearing retaining nut.AUTOZONE orADVANCE AUTO sells them.They're cheap.The front bearing can be accessed from the front.Remove the brake caliper and the rotor to access the rear bearing.you'll need new seals for the rear of the rotor.I would also check front steering linkage and suspension.It is pretty simple to replace frontend components yourself.Alot cheaper than a shop.You could do the whole front end for a few hundred dollars.The Death wobble is a sign that shouldn't be ignored.Good luck and get the CHILTONS BOOK it will help you save a ton of cash.
Old 01-17-2012, 09:24 PM
keyul's Avatar
Thanks for the input, I do have a haynes manual, I am really not to fond of it. I wasnt aware that walmart sold chiltons!
80-87 Flareside bed parts keyul Ford Truck Parts for Sale 18 11-14-2015 11:20 PM
Spindle suggestions keyul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-31-2012 09:38 PM
4x4 hub, need help! keyul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 36 01-29-2012 11:14 PM
What causes locking hubs to go boom!? keyul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 05-24-2010 07:50 PM
82 f150 4x4 not working properly keyul Clutch, Transmission, Differential, Axle & Transfer Case 4 04-20-2010 08:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
