1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Knocking sound from center dashboard area?
Old 01-15-2012, 08:00 PM
gddyup's Avatar
gddyup
gddyup is offline
Hey fellow Ford Super Duty fans! I just picked up my 2008 F250 Crew Cab a few days ago. It's got 56k on the clock and a 3/36 bumper to bumper warranty on it. I absolutely LOVE the truck and have no regrets from trading in my 07 Expy Limited for it. It;s a 5.4 gasser with the Lariat package. My question stems from a weird "knocking" sound coming from what sounds like the center dashboard area. I've been trying to lock down a specific scenario that makes it happen but have as of yet not really gotten to that point. It's a noticeable "knock-knock-knock" sound that *may* be a blend door or HVAC control system that is going awry but I'm not 100% positive that that is what it is. The sound seems to come from somewhere in the center portion of the dash but it seems to be unrelated to HVAC flow position or fan speed. I do notice that the "face" vents don't always flow what they should. In order to get the "face" vents to flow I have to switch to another flow option and then come back to them. Whether this is just a weird hiccup or a possible issue with a blend door, I'm not sure. I've tried turning the HVAC system on and off while hearing the noise but it's not consistent. Sometimes the noise goes away and sometimes it doesn't...
Guess I'm just looking to see if anyone else here has had a similar issue. It *could* be something under the hood that is transmitting to the interior but I'm not quite sure at this point.
If anyone has any ideas, comments, or suggestions, I'd love to hear them.
Old 01-15-2012, 09:14 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Cant really help but just wanted to say congrats on the new ride
Old 01-15-2012, 10:29 PM
Boss08v10's Avatar
Boss08v10
Boss08v10 is offline
I have the same knock sound in my 08 SD. No idea what it is from and I can only hear it when stopped and idling. I do notice it more when it is cold out versus warm.
Old 01-18-2012, 12:37 PM
gddyup's Avatar
gddyup
gddyup is offline
Quick update - The sound as driving me nuts this morning while I was waiting in the parking lot to pick up my youngest son from school. If I put my hand under the dash and feel the bottom of the center HVAC case, I can feel a ticking inside the case in relation to the noise. Along with the knocking noise, I can hear what sound like a servo that is running. So, I'm almost positive it's a broken or worn door servo motor or blend door motor that's having a fit.
Time to make an appt. with the dealer. Can you say "Warranty?"
This repair alone will probably make up for 1/2 what I paid for the warranty coverage. Not bad...
Old 01-18-2012, 05:55 PM
smotrs's Avatar
smotrs
smotrs is offline
Definitely sounds like blend door(s) from your description. I've had both mine replaced under warranty. It's an expensive repair if out of warranty.
Just explain to dealer you have a continuous dull knocking sound coming from behind the dash.
Old 09-09-2013, 12:01 PM
acf6's Avatar
acf6
acf6 is offline
Idling in my bosses 09 f450 lariat right now, and its doing the same thing. So it turned out to be the blend door(s) being defective?
Old 09-09-2013, 12:34 PM
gddyup's Avatar
gddyup
gddyup is offline
Yep. Mine was a defective blend door actuator.
Old 02-02-2015, 12:13 PM
tobyw's Avatar
tobyw
tobyw is offline
Bringing this back up from the dead...
I just picked up an '08 F-250 that has this noise, although my vent locations all function as expected. Still, I know it's not right. Has anyone done the repair on their own? There is what appears to be a servo on the passenger side just above the tranny hump that I can hear and feel humming and popping, so I know it's the culprit, but haven't found any info on replacing it yet. Thanks for any input!!
Old 11-16-2023, 04:12 PM
Chelsea_Rai's Avatar
Chelsea_Rai
Chelsea_Rai is offline
1st Gear
What ended up happening in your situation? Were you able to do the repair yourself? Having the same situation on my 07 and hoping it's not too difficult.
h20camper
2017+ Super Duty
16
11-06-2018 01:36 PM
firecatab
6.4L Power Stroke Diesel
10-12-2013 01:42 PM
EXv10
08-15-2013 05:41 PM
JSNorthskyFTS
2004 - 2008 F150
06-28-2009 09:24 PM
JerrySC
3.8 & 4.2L V6
01-27-2008 11:19 AM
Quick Reply: Knocking sound from center dashboard area?
