223 to 302 SWAP - Ford Truck Enthusiasts Forums
223 to 302 SWAP
Old 01-15-2012, 08:15 PM
chuckly727 chuckly727 is offline
chuckly727 is starting off with a positive reputation.
Question 223 to 302 SWAP
Hello, I am new to this forum, I just purchased my dads 1960 ford f100 its an old farm truck my family and I had and the truck I learned to drive on. I am wanting to swap out the old 223 that it has and drop in a 302. It has a 4 speed trans and not sure about the rear end. I was just wondering if anyone could give me some info or places I could look to learn how to do this I am used to just fixing the engine that is in the car and not doing a swap however I think it would be easier to find parts and go the direction I want with the 302. Also any good places to look for a good 302 would be great also. Thanks in advance for the help.
Chuck
Old 01-15-2012, 10:11 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Here's some talk abut this topic: http://www.ford-trucks.com/forums/95...-a-1960-a.html
If you do a google search and go to advanced search and enter the name of this web site www.ford-trucks.com to search in, you will come up with a lot more conversation. This topic has been batted around many times. Be patient and keep searching different word combinations and you will score tons of info from here.
Old 01-16-2012, 02:08 AM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
I have a '58 F 100 and I built a 351 W that I put in it. Since they are both small blocks I can tell you what I did. I positioned the motor where I wanted it and made some motor mounts out of 4" c-channel. I bolted the mount I made to the frame and then bolted the engine mount to it. It stayed there until I did this Crown Victoria front suspension swap that I am currently working on. Also I am using a FMX auto trans so I had to use a B & M shifter.
For the radiator I bought an aluminum 4 core radiator from summit racing the size that I needed with an electric fan for clearance issues. I also had to make radiator mounts. I'm sure you could buy some but I'm not made of money so I made mine. Also I had to go to a junk yard and buy a drive shaft of the correct length. Of course when I got the truck it was just a rolling body. I had to put everything in from the turn signals to the gas tank and everything in between.
The actual making of the motor mounts wasn't too bad. Once you get the motor where you want it, cut a piece to bolt to the engine mount. Then cut a piece to go from that piece to the frame. Then cut another to go from the piece bolted to the frame down to the bottom of the frame for support. If you have a grinder with a cut-off wheel and at least a stick welder, you can do it. (that is all I had at the time)
I hope this helps. Don't be afraid to mess something up because you can always: a.) fix it or
b.) buy another one.
Old 01-16-2012, 02:25 AM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
tbirdscott is starting off with a positive reputation.
For your engine look for 89-93 thunderbirds and cougars for an HO engine or better yet a 96-01 explorer for a better starting point. Cheaper and easier to find than the ones out of mustangs, usually in better shape too.
Swap in a duraspark distributor and you can either run the factory duraspark or any aftermarket box you like off it. Then add a carb and intake of your choice and your motoring!
Scott
54 F-100 engine swap from 223 to 289 or 302 questions rpaxton939 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 09-09-2016 11:10 PM
Chucks Trucks LLC 1oldtimer 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 04-30-2013 09:48 PM
1960 F-100 Engine/trans upgrade to ???? Suggestions??? darray 1957 - 1960 F100 & Larger F-Series Trucks 33 08-11-2012 09:34 AM
92 Truggy with SAS rlee3 Offroad & 4x4 5 04-16-2012 01:05 AM
223 TO 302 SWAP QUESTIONS chuckly727 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-15-2012 06:01 PM
Tags
1957, 1960, 2004, 223, 302, 59, crown, engine, f100, ford, motor, mounts, swap, swapping, victoria
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
