F150 to F250 suspension swap... - Ford Truck Enthusiasts Forums
Old 01-15-2012, 06:46 PM
4601ton 4601ton is offline
4601ton is starting off with a positive reputation.
I've always been disappointed by how stupidly easy my 87 F150 2wd squats. I swear an empty Solo cup will make it sit level. So, I had a thought...in the local Pull-A-Part, there's a "mint" (just put there) 97 F250HD Super Cab shortbed 2wd with a 460...it was a state truck, I'm not even sure how it got damaged...something crushed the COWL...not the roof...not the hood. The cowl, windshield and dashboard.
So I thought about stripping all the suspension out of it, rear axle, springs, beams, everything and putting it under my 87 F150 rclb 2wd...is this pretty much a bolt-in swap like I'm thinking? I'd love to make it more heavy duty...straight 6 and all...
Old 01-15-2012, 06:54 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
It'll bolt in fine, but it'll ride really rough. You'd be better off getting a newer set of F150/Bronco springs.
Old 01-15-2012, 07:06 PM
Lol the rough ride doesn't worry me. I've had plenty of HD trucks...the ride doesn't worry me...just reminds me of how much it can handle...
Old 01-15-2012, 07:08 PM
Edgethis's Avatar
Just cause you swap 3/4 ton springs on it doesn't mean your load rating goes up....
Old 01-15-2012, 07:13 PM
Not just springs. Everything but the frame. Then my weak links will be the frame and the SROD transmission...my list of items to get...
1. Rear axle
2. Rear springs/hardware
3. Front beams/hardware
4. Front springs/hardware
5. Front spindles/brake calipers/rotors
6. Possibly brake booster/MC/proportioning valve
7. F250 badges off an 87-91 era truck if I can find them...heheh.
I may never need that much capacity, but doing all that is like carrying a condom...it's better to have it and not need it then need it and not have it.
Old 01-15-2012, 07:19 PM
Edgethis's Avatar
Not sure how the front suspension is on a 250HD 2wd but that may not bolt up without some work.
Old 01-15-2012, 07:41 PM
Yea, the front suspension was my concern. I'm not gonna add the 3/4 ton springs without the rear axle (it'd be like putting splayed main caps on a Yugo engine) and I'm not swapping the rear axle without the front setup...two sets of wheels would be stupid as my ex-wife.
Old 01-15-2012, 08:10 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
I think it would be just better, and easier just to get a F250 or 350 and drive that, if you really load your self up good.
If not, then enjoy the luxurious ride of your F150
My '89 has rather soft suspension to, and I hauled my old storage trailer with it, the trailer is loaded and weighs around 4500lbs.
Old 01-15-2012, 08:20 PM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
Upgrade all that stuff and it still doesn't change the truck's GVWR, so you still can't legally carry any more weight. Sounds like your springs are just old and worn out. Just get yourself a NEW set of 5 leaf springs. Some F-150s came with 4 leaf springs and some had 5. The ones with 5 leaves are the same ones in an F-250 anyway.
Old 01-15-2012, 08:22 PM
Eh, I suppose if I can't swap it I'll just keep the "truck" around as a driver...and find a real truck for work. The point was to upgrade the truck I have...but I understand if it's not possible/not really feasible. I just really like HD trucks...and seeing this 1/2 ton squat when I stand on the tailgate (I'm 173 lbs) just annoys me and screams "weak"...
Old 01-15-2012, 08:34 PM
You can get a set of "overloads" for the back.
My '88 F150 parts truck had some. Had the stock 5, and another 5 overloads on top of it.
Old 01-15-2012, 08:42 PM
Yea, I'll do something with it. Thanks for the input guys...guess she'll stay a 1/2 ton...
Old 02-27-2014, 08:02 PM
01Powerstroke4x4 01Powerstroke4x4 is offline
01Powerstroke4x4 is starting off with a positive reputation.
will the f250 suspension bolt up to the f150 besides front leaf springs
Old 02-27-2014, 08:04 PM
Will the f250 suspension bolt up easy besides the leaf springs on the front
Old 02-27-2014, 08:11 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
2wd f250s do not have front leaf springs, they have coils, just like f150s
Also 2wd F150s have 2.5" rear leaf springs, F250s and up have 3" slings, so you would need to change the riveted on hangers too.
Like others have said, just put a NEW set of F150 springs in(get the heavier ones) and it will be a super improvement
F250 4x4 leaf to coils D50 TTB BlueOvalBud 1987 - 1996 F150 & Larger F-Series Trucks 7 01-23-2017 07:28 PM
Collapsed hood? fordboy300 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 01-16-2016 11:25 AM
Swapping out cowl and hood with a '92? iwals 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-16-2015 07:27 PM
Body swap vs. Drivetrain swap maddogjohnson 1973 - 1979 F-100 & Larger F-Series Trucks 10 09-06-2015 09:20 PM
Heres the lift and tires I'm about to buy? j.cowling 1999 to 2016 Super Duty 14 01-16-2014 09:35 PM
Tags
1979, 1987, 1995, 250, 350, axle, codes, f150, f250, ford, make, springs, suspension, swap, swapping, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
