e250 rearend - Ford Truck Enthusiasts Forums
e250 rearend
Old 01-15-2012, 05:07 PM
79zron 79zron is offline
79zron is starting off with a positive reputation.
e250 rearend
I got a 1993 e250 work van, and need to replace the rear, it has a axle code of 24, 3:73 if i'm correct, but what other years and models will fit my van? will a e150 fit and is it as strong or is there no difference?
Old 01-18-2012, 11:48 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
E150 has 5 lug wheels, while your E250 has 8 lugs. So that's a no no.
Any van axle, from 1975-91 are the same, but it "should" be the same from 75-98?
Old 01-24-2012, 05:40 PM
kb1jid kb1jid is offline
kb1jid is starting off with a positive reputation.
Where are you located? I have one from a 1990 E250 with 3.73 gears it could use a brake job. Iam in ma. cheap
Old 01-25-2012, 12:29 AM
Quote:
live in pgh pa
1997 E250 Cargo Van gurlracer77 1968-2013 Full Size Vans 3 08-28-2014 07:44 AM
Swap a 1996 E van 351 in to a 1991 F250 with a 302? todd512 1987 - 1996 F150 & Larger F-Series Trucks 2 06-25-2014 11:58 PM
99 E150 Conversion Van Gauge Pod daghstdrummer 1968-2013 Full Size Vans 9 11-12-2013 08:27 PM
E99 van turbo questions JT250 1999 - 2003 7.3L Power Stroke Diesel 0 08-23-2013 07:25 PM
6.0 E350 van intercooler fitment? JT250 1999 - 2003 7.3L Power Stroke Diesel 5 02-25-2011 10:43 PM
Tags
1987, 79, 91, axle, diesel, e250, end, f150, f250, fit, ford, reading, rear, specs, tag, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
