will a c6 transmission bolt up? - Ford Truck Enthusiasts Forums
Old 01-15-2012, 03:53 PM
360F100's Avatar
360F100 360F100 is offline
360F100 is starting off with a positive reputation.
Will a 300 I-6 bolt up to a C6/C4 auto trans?
Old 01-15-2012, 03:55 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Yes. The 300, 302, and 351 all share the same bolt pattern. As long as it's for a small block.
Old 01-15-2012, 04:11 PM
360F100's Avatar
aaahhhh dangit..Its from a FE motor. Ok well i apreciate your help.
will a c4 trans. mate to a 223? crm318 Engine Swaps 21 06-26-2015 09:31 AM
Will a C6 bolt up to a 302? GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 09-03-2010 12:19 PM
Will an Efi 460 fit a C6 Transmission RPikulski Clutch, Transmission, Differential, Axle & Transfer Case 3 12-27-2004 08:44 PM
c4\c6 tranny rexx Ranchero & 1961 - 1967 Econoline 13 12-12-2002 04:17 PM
C6 for 351 cleveland canadianfordman Clutch, Transmission, Differential, Axle & Transfer Case 7 05-10-2002 05:44 PM
Tags
292, 300, 49, 50, bolt, c6, cyl, engine, f150, ford, inline, straight, tranny, trans, transmission, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
