Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- How to Replace Transfer Case Motor
Step by step instructions for do-it-yourself repairs
transfer case motor question
Hi guys..Long time member first time posting. First I just wanna say that this site is the best. Never needed to post before to day because the answer to any question I had is floating around here somewhere.
So I need to replace the transfer case motor but the two wires that lead to the transmission tail shaft have me stumped. I'm sure they are for some type of speed sensor but how do I disconnect them from the motor itself. One is a ground and the other goes into the tail shaft. The truck is an 07 model.
Thanks,
Stephen
Thanks,
Stephen
Above(Specialty tools)
Disassembly
Transfer Case Exploded View - Manual Shift
Transfer Case Exploded View - Electric Shift
NOTE: On the manual shift transfer case, place the transfer case in the neutral position for disassembly.
- Remove the transfer case
2.Remove the 4WD indicator switch, if equipped.
3.Using the special tool, secure the transfer case.
4. Using a suitable tool, remove the oil seal.
5. Remove the coil wire from the electric shift motor electrical connector, if equipped.
<TABLE border=0 cellSpacing=10 cellPadding=1><TBODY><TR><TD vAlign=top>1
</TD><TD vAlign=top>Remove the wire connector spacer. </TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Remove the coil wire and pin.</TD></TR></TBODY></TABLE>
- Use an electrical connector pin extractor tool.
6.Remove the Output Shaft Speed Sensor (OSS) , if equipped.
7. Remove the transfer case shift motor, if equipped.
</TD><TD vAlign=top>Remove the bolts. </TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Remove the transfer case shift motor.</TD></TR></TBODY></TABLE>
8. Remove the extension housing.
</TD><TD vAlign=top>Remove the six extension housing bolts. </TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Remove the extension housing.
9. Remove the speed sensor tone wheel, if equipped.
</TD><TD vAlign=top>Remove the tone wheel spacer clip. </TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Pull off the speed sensor tone wheel and discard.
10. Remove the rear output shaft snap ring. IA up on the output shaft while removing the snap ring
11. NOTE: The bolts are self-tapping, and it is normal to find metal shavings while removing the cover. Remove the bolts.
12. NOTE: Use pry bosses to separate the cover from the case. Separate the transfer case covers.
13. Remove the coil.
</TD><TD vAlign=top>Remove the three coil-to-cover nuts. </TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Remove the coil.
14. Using the special tools, remove the rear output shaft bearing
15. Using the special tools, remove the front output shaft bearing.
16. Remove the shift collar hub soap ring
17. Remove the coil housing.
18. Remove the shift fork.
</TD><TD vAlign=top>Remove the lockup hub. </TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Remove the shift fork and spring.</TD></TR></TBODY></TABLE>
19. NOTE: Remove the lockup hub assembly as a single unit. If disassembly is required, proceed with the following. Disassemble the lockup hub assembly.
</TD><TD vAlign=top>Remove the lockup hub snap ring. </TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Separate the lockup collar. </TD></TR><TR><TD vAlign=top>3</TD><TD vAlign=top>Separate the two lockup springs. </TD></TR><TR><TD vAlign=top>4</TD><TD vAlign=top>Separate the lockup hub. </TD></TR><TR><TD vAlign=top>5</TD><TD vAlign=top>Remove the armature.
20. Remove the spacer.
21. Remove the drive chain and sprockets as an assembly.
22. Remove the magnet from its slot in the case.
23. NOTE: The pump assembly is not repairable. Remove the oil pump and the output shaft as an assembly.
24. Remove the shift rail.
25. Remove the shift fork and the reduction hub.
</TD><TD vAlign=top>Remove the shift fork.</TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Remove the reduction hub.</TD></TR></TBODY></TABLE>
26. WARNING: Do not disassemble shift cam assembly. Remove the electric shift cam assembly, if equipped.
27. Using the special tool, remove the input seal.
28. CAUTION: Do not let the front planet carrier fall while removing the snap ring. Remove the front planet carrier.
</TD><TD vAlign=top>Remove the front planet carrier snap ring.</TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Remove the front planet carrier.
29. If necessary, using the special tools, remove the bushing from the front planet.
30. Using a drift and a hammer, remove the needle bearing, if necessary.
31. Remove the ring gear.
</TD><TD vAlign=top>Remove the ring gear snap ring. </TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Remove the ring gear.</TD></TR></TBODY></TABLE>
32. Remove the front planet carrier bearing snap ring. Then, using the special tools, remove the front planet carrier bearing.
33. CAUTION: Do not let the front output shaft fail while removing the snap ring. Remove the front output shaft.
</TD><TD vAlign=top>Remove the front output shaft snap ring</TD></TR><TR><TD vAlign=top>2</TD><TD vAlign=top>Remove the front output shift.</TD></TR></TBODY></TABLE>
34. Using the special tools, remove the front output shaft bearing
35. Using the special tools, remove the front yoke to flange seal.
36. NOTE: Access the shift. lever set screw through the 4WD indicator switch hole, if equipped. Loosen the shift lever set screw.
37. Remove the shift lever (from outside of case), shift cam detent spring and detent roller, if equipped.
38. Using the special tools, remove the shift lever seal, if equipped.
39. Using a suitable pry tool, remove the electric shift motor seal, if equipped.
40. Remove the dust shield, if necessary.
I know theres a bit more than needed but I figured it would come in handy
all info above is from www.alldatadiy.com
Another clarification......one wire coming off the motor is grounded on a tailshaft bolt. The other wire goes into the the tailshaft itself. After unplugging the harness and unbolting the motor, these wires are the only thing from keeping me from getting this motor off the truck. The wire that is grounded to the bolt is easy enough but the wire going into the tailshaft has no way (that I can see) to disconnect. Any help with this would be greatly appreciated.
Stephen
Stephen
47studebaker
12-27-2005 12:59 PM
