5.4L F250 Won't Start - PCM? - Ford Truck Enthusiasts Forums
Old 01-15-2012, 11:00 AM
bigjimd bigjimd is offline
bigjimd is starting off with a positive reputation.
So I parked my truck (2005 F250 5.4) and it was working fine. The next morning she turns over but absolutely refuses to start. I've messed with it for 6 hours now and am out of ideas.
-Added dry gas thinking maybe gas lines froze up
-Checked all fuses / relays
-Tried starting it on ether (dad's insistance, didn't work)
SO I think it has to be an ignition problem. I don't have any mechanic friends around to give me free advice so I'm turning to you guys. I've googled everything I can think of and it seems the most likely explination is the Powertrain Control Module took a dump?
It was verrrry cold last night. I don't know if that's relevant. I REALLY NEED this truck for work tomorrow so any suggestions are very appreciated. I have a Chilton manual and am working my way down checking everything I can think of.
ALSO the horn is stuck in on all of a sudden. I don't think its relevant. I just pulled the fuse for it and will deal after I get the truck running. THANKS for any tips / advice / links to people that have similar problems.
Old 01-15-2012, 11:41 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I would start by scanning for codes. Could be as simple as a crank position sensor.
Old 01-15-2012, 12:14 PM
Quote:
Yea I forgot to mention that I did scan for codes and there were none. I've been messing with it some more and haven't gotten anywhere. Thanks for replying though.
Old 01-15-2012, 12:31 PM
Quote:
ALSO I just read somewhere about a "soft code" - is it possible the truck is throwing codes and my scanner is too cheap to pick them up?
Old 01-15-2012, 08:35 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
Can you hear the fuel pump running when you turn on the ignition , have you checked for fuel pressure ?? my first guess would be fuel pump..
Old 01-15-2012, 09:29 PM
FoxNotch FoxNotch is offline
FoxNotch is starting off with a positive reputation.
I had the fuel pump on my 05 die out of nowhere.
This also uses a fuel pressure control module, which mounts on the crossmember by the spare tire. Track down the fuel pump relay and check that out as well.
Good luck.
Old 01-16-2012, 07:42 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
PCM failures aren't all that common although they do occur.
You'll need to eliminate the most likely alternatives before coming to that conclusion.
Old 02-08-2012, 01:09 PM
patrolkall patrolkall is offline
patrolkall is starting off with a positive reputation.
Same problem?
HI.
Thanks for a great forum, it has helped me alot with my f250.
I have seem to have the same problem as bigjimd any results from yours bigjimd??
My F250 is a 2005 5.4. I tried a new fuel pump module but it still wont run and i cant hear the fuel pump altough i open the gas cap.(will it need ground from the housing? i did not attach it)
Old 02-08-2012, 08:25 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Hit the bottom of the tank with a rubber mallet and listen for the pump.
Old 02-08-2012, 09:56 PM
Here's a link to my fuel pump failure thread a few years ago:
http://www.ford-trucks.com/forums/90...f250-5-4l.html
Old 02-02-2016, 06:54 AM
smares smares is offline
smares is starting off with a positive reputation.
Cool Damn!!! Really Guys?
You post such a common and frustrating failure like this that would've helped literally hundreds, if not thousands of Ford truck drivers with this kind of problem, and then you go and leave the entire thread hanging without posting a resolution???? WTH!???? Does anyone know the likely solution to this kind of problem? Does anyone know how this guy fixed his issue he was having in this thread?
I'm having the same exact problem. The fuel pump is sounding off when the key is turned. I've verified fuel pressure at the air bleed valve on the fuel rail, I've verified the various PCM related fuses are good in both the passenger, and engine compartments, and I've swapped around any PCM related relays I could find. The engine is turning over fine when I try to start it, but it doesn't seem to be firing. I'm going to check the camshaft sensors today. Is there anything else I should/could look at?
SO FRUSTRATING! No warning, no degradation of engine performance, and now, the next morning it just won't start.
Old 02-02-2016, 07:49 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
We do the best we can with any and all data presented----we have no way of knowing what did or did not resolve OP's issue as he hasn't updated his thread in over 4 years.
All advice offered him applies to your situation as well---first scan for DTC's. If something has failed preventing starting it should show up there.
Most new users hate speculations or guessing especially if they're unfamiliar with diagnosing or troubleshooting automotive issues. As such we tend to hold back and wait for DTC's to be shared----we're able to be more helpful then.
Simply put the help obtained here cannot be better than the information offered. Try as we might mind reading isn't part of the deal here!
Old 04-22-2016, 02:42 PM
ben_evel ben_evel is offline
ben_evel is starting off with a positive reputation.
same problem as above.
I have the same problem as above. I did however spray starting fluid in the airbox and it started. I shut it off after a couple seconds and it started right back up. drove it all day with no issues. then in the morning i went out to start it again and the same thing happens. acts like no fuel. I replaced the fuel pump and played with some relays. we shall see in the morning i guess.
Old 04-22-2016, 08:28 PM
Quote:
You need to OBSERVE the THEFT light to see if PATS is the issue.
Old 04-22-2016, 11:49 PM
I ended up replacing the fuel pump, yet I still had no pressure up at the fuel rail even after I did all that. Initially, I could Spray starting fluid into the intake, and it would rumble to life, but only for a second or two. Then after I replaced the fuel pump, even that stopped working. It wasn't even getting spark now. So I deduced that the pcm had shut everything down for some reason. It wasn't allowing the fuel pump to pump, or the plugs or injectors to fire when I tried cranking the engine. The pump prime cycle always worked. It seemed to pump fuel great during that cycle when turning the key to the run position. I had also checked the camshaft position sensor early on in this process, but I didn't know about the crankshaft position sensor. I found that sensor, and traced its wiring from the bottom of the engine, up over the exhaust manifold, and over the valve cover on the passenger side of the engine towards the back of the valve cover, and that wiring appeared to be tight around a valve cover bolt at the back of the valve cover. It was so tight, it appeared to have rubbed through the wiring casing, and very well could have been shorting out that signal from that sensor. I decided to try starting it after moving that part of the harness, and it roared to life!
92 F150, 302 5.0L - cranks but won't start! breno1987 1987 - 1996 F150 & Larger F-Series Trucks 25 09-15-2016 08:06 PM
2001 explorer sport - no parking or instrument lights SteveCarter Electrical Systems/Wiring 5 09-16-2015 05:53 PM
99 F-250 superduty intermittently starts Nick-koziol 1999 to 2016 Super Duty 9 03-21-2015 03:49 PM
reset service engine light buckarooboy 1997-2006 Expedition & Navigator 6 11-01-2012 09:30 PM
Never-ending Smog codes..31, 32, 34, 41 timbersteel 1987 - 1996 F150 & Larger F-Series Trucks 13 11-02-2010 09:04 PM
Tags
03, 1994, 54, duty, f250, ford, fuel, gas, location, pump, relay, start, super, v10, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
