best spark plug? - Ford Truck Enthusiasts Forums
best spark plug?
Old 01-15-2012, 02:44 AM
AppocAlexx's Avatar
AppocAlexx AppocAlexx is offline
AppocAlexx is starting off with a positive reputation.
best spark plug?
i have recently purchased an 2001 F150 with a 5.4L engine. i am goin to do a some tune up and upgrades to the truck and was starting with a few things like the spark plugs. i have an 87 5.0L mustang and have always ran the bosch platinum 2s and i believe that i am only supposed to run either motorcraft for autolite in the modular engines. my question is what is the best performance spark plug i can get or do i just stick with the motorcraft. i personally have never liked the autolite just bc a lot of the times i have changed spark plugs in the fords and i pull autolite out they look way worse than i have ever seen motorcraft. they just seem cheap to me. any info would help. thanks to all.
Old 01-15-2012, 07:41 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Most with that motor---including myself---use the MotorCraft brand but the equivalent Autolite part works well too. Most who've veered from the MC or AL brand seem to experience a loss of performance and MPG's.
While I don't know for certain I once read most aftermarket plugs regardless brand name do not have the same thread profile as MC & AL, that the plug holes in the heads have a different thread profile which MAYBE contributes to blown plugs. Along with using anti-seize there might be a disagreement but in general MC or AL are the recommended plugs to use.
Check your COP boots too----they tend to give problems if cracked or worn out due age.
HTH
Old 01-15-2012, 11:37 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Yep, MC or AL and make sure they are the platinum.
Old 01-15-2012, 11:57 AM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
I used (2006 Mark LT) Motorcraft SP 515’s
Old 01-15-2012, 12:40 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Motorcraft Double platinum plugs will run best in your 2001 F150.
Old 01-15-2012, 12:55 PM
AppocAlexx's Avatar
if i do the double platinum mc do i have to watch out for the plugs burning to hot...i just heard by word of mouth that it could burn a hole throught the piston or piston wall is that true bc iv never seen it...lol thay might be a dumb question sorry. but like i said i used them in my 5.0 and never had a problem they ran great from what i could tell.
Old 01-15-2012, 08:14 PM
keisha9 keisha9 is offline
keisha9 is starting off with a positive reputation.
uhhhh sp515 is the name. motorcraft built
Old 01-15-2012, 08:39 PM
Quote:
No....each plug has a specified heat range, whether its non-platinum, single plat., double plat., etc......with as thin of electrode as is being run, the double plat. plugs will have greater durability to last longer....much longer than a single plat.
Old 01-15-2012, 08:44 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
SP515 is only for the 3v 2004+ engines.
Old 01-19-2012, 08:41 PM
hcbph hcbph is offline
hcbph is starting off with a positive reputation.
Plugs
I have 07 with a 5.4 Flex Fuel engine. I put Champions in about 10K ago and I seem to be the exception to the rule. No drivability issues, no negatives with the Champions. I even picked up a little mpg in the process (changed out the MC's at 42K) over the MC plugs. I have nothing but positive comments and not having any 2 piece plugs in the engine is a benefit.
Mine is 100% stock mechanically and that might be why mine is working so well. I've gotten 20.6 mpg out of it on the highway (19.3 best with the MC's) and that's not bad for a Heavy Half SCab, 8' box with 4.10's in it. I average around 15 mpg in town on winter gas.
2006 E-250 5.4 spark plugs aj197816134 Modular V8 (4.6L, 5.4L) 1 03-18-2014 08:58 PM
spark plugs 1999stroke 1967 - 1972 F-100 & Larger F-Series Trucks 2 01-31-2014 04:29 PM
another spark plug question brianjordanf250 1999 to 2016 Super Duty 26 11-07-2012 03:19 PM
Autolite Spark Plugs and Coil Problems t.colosino1 2004 - 2008 F150 3 12-21-2010 04:13 PM
Champion,autolite,or motorcraft plugs..and part#question rferoni 2004 - 2008 F150 11 12-30-2009 11:13 AM
Tags
2007, 54, 56, bed, f100, f150, f250, ford, heat, motorcraft, performance, plug, plugs, range, sp515, spark, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
