How to change fuel filter?
You need to loosen the bale using the bolt on the bottom so you can move it off to the side of the glass bowl. Inside the housing will be a piece of brass screen to keep large particles out, that is the extent of the filtration lol pretty basic.
I would recommend installing a disposable inline filter between the fuel pump and carb to catch the smaller stuff the glass bowl will miss.
Scott
Scott
I plan on putting a filter on at some point but I would like to take my time planning where to put it. I would prefer not to cut the metal lines. There is the screen in the pump and a screen right before the gas enters the carburetor. Just to see if I can get the truck to run will it hurt to run the truck without an inline filter. The screens appear to be rather fine.
Worst that can happen is you push some crap in to the carb then it will need to be cleaned. If your confident in the fuel go for it, it should be fine. How long has the truck been sitting for? Have you gone through the carb?
Another thing you could do temporarily is disconnect the fuel line at the carb and slide the fitting back far enough on the line to get a piece of fuel line on it then install a barbed fitting in to the carb and use a loop of fuel line and a filter there.
MeanGreen72
12-13-2020 03:34 PM
azroxx
13
12-16-2018 06:46 PM
460_Sprout
10-22-2004 06:26 PM
