ZF 5 speed in 88 F350
I am attempting to ring a little more MPG from our F350/460 work truck.
The local self service JY is beginning to get in some of the manual F350 gassers
The trannies go for a <$200. price.
Were the early ZF 5 speeds behind gassers any good or am I just opening another can of worms.
The current c6 / 354 works fine I just want to explore all options.
Wonder what mpg improvement I would get with an ZF 5 speed OD manual vers the C6 slush box.
Would it ever pay for its self??
But there is nothing like a big engine and a manual.
Does anyone have any first hand experience with the ZF 5 speed behind an FI 460 in an F350?
ZF 5 (5 sp) S (syncronized) 42 (420 ft/lbs)
ZF 5 (5 sp) S (syncronized) 47 (470 ft/lbs)
I have over 500K on mine behind a 5.8L gasser, though I rebuilt mine somewhere between the 250-300K range because one of the syncros decided to de-syncro-nate (disintegrate).
Rare occurrence actually, they're very nicely made transmissions.
Regarding MPG, that depends on how you shift. Bang redline a lot and you'll use far more gas. When I'm driving locally, I tend to shift "crazy low" since there's no point in accelerating hard around here with all the windy residental roads. So by 25 mph, I'm generally in overdrive.
Basically its bullet proof
I have about 215,000 in mine and it has served me very well. On a ZF you MUST use ATF as the lube the tolerances and clearances are that tight .... any thing else will NOT get into all the areas needed. I use 1/2 cup of Lucas oil treatment each change and NO more just because I am bullheaded. I have a friend who went to school on the ZF and he loves them cuz of their durability ... but they are NOT cheap to fix. I only run the Lucas in the summer because of the Vegas area heat all in all GREAT trans. Dave
