You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I found out today that my ECM for my 460 is apparently bad. The truck is actually an 86 I have updated. The present system is from a 1990 F250. I can use probably anything up to 1995 as the front harness is actually from a 1993 truck. It needs to be a Speed Density Bank Fired system for a 460 W/E4OD.
Thanks
__________________
Bill Vose (Old School Hot Rodder) 1986 F350 crew cab DRW 460ci EFI, E4OD, PMGR starter, 160 amp 3G alternator, 12X3 rear brakes, Traction lock 3.55
1995 Lincoln Continental (project car), 1994 Taurus LX (daily driver) http://www.oldschoolhotrodder.com
"growing old is inevitable, growing up is optional"
hello, I went looking for one myself yesterday and found a 97 f250 hd. the guy wants 100.00, its the one with the ALT0 code part# f6tf-12a650-aha.
It's the same part number i'm running right now in my 67, but i read somewhere that it is basically a heavy duty emissions computer, and i noticed while monitoring data, cruising down the highway that it goes in and out of closed loop. uses way more gas that my original ecm out of a 92 E350 which only flaw is not being data capable.
So i'm also in the quest for a different ecm myself.
if you are not in a hurry i could sell you either one of mine for cheap, once i find the right one for my purposes.
by the way do you know the member's name in the 460 forum that knows the ecm's part #s ?
thanks.
thanks.
I don't right off know the name of the guy on the 460 forum who knows the ECM numbers, but it might be the fellow who runs reincarnation performance. I need a ECM that will run an E4OD transmission and a 460 so if one of those is correct I would be interested. Is the F6TF-12A650-AHA an OBDII system, 104 pin or is it the OBDI 60 pin?
Thanks for the reply.
__________________
the F6TF-12A650-AHA is 60 pin and controls the E4OD but like i mentioned is heavy duty emissions. if you want i could buy it for you and send it along or i could try your ecm in my truck and see how it runs and what can be wrong with it.
Forgot to ask where are you located?
and also i noticed you mention digital storage osciloscope in your other post, are you an auto tech? if so show me the secret handshake.
no seriously maybe give me a call I'd be able to help you. 2 heads think harder and what not.
any ways I'll anwer you on the 460 forum post , maybe we can get this 460 guru
to help us both.
to help us both.
I used to make my living doing this, but recently retired after almost 30 years in materials testing and calibration. The scope is an Extech handheld LCD model 381295A and is for primary circuit use only. I went to 460Ford.com, It may be the guy on there, Scotty AKA the Mad Porter. I asked there for anyone with a list of compatible ECMs.
Location, Newport News, VA. Mobile number 757-593-9642
__________________
Update on this one, ctubutis found me a 92 EEC, but the problem turned out to be the electronic speedometer. I had a speedometer shop reset the mileage to match the 86 speedometer and they also do any upgrades, repairs etc. to bring it up to date. One of his new techs removed the filter circuit and forgot to replace it. It was telling the EEC the truck was moving when sitting still causing the lockup clutch to engage as soon as it was put in gear.
__________________
Hi there, it's great to hear the good news.
so which ecm are you running ?
is the '92 data capable? if so i may be interested in buying it or trading you for the '97 ecm i have. thanks
