Keyless Entry on Explorer Sport 2001 - Ford Truck Enthusiasts Forums
Old 01-14-2012, 03:26 PM
askbruce askbruce is offline
askbruce is starting off with a positive reputation.
I have power door locks.
How do I know if I have keyless entry?
I would like to buy a fob and program it if possible.
Thanks
Old 01-15-2012, 10:02 AM
1081's Avatar
1081 1081 is offline
1081 is starting off with a positive reputation.
I just turn the key "on" then "off" 5 times and if the doors lock then unlock by themselves for one cycle then it goes in to programming mode...hence it is set up for it. Or check the VIN and it should show it as one of the options.
Old 03-16-2012, 01:12 AM
tongdies tongdies is offline
tongdies is starting off with a positive reputation.
Try keylessride.com, if you enter your vin# it will tell you. I have heard this works, haven't tried it myself.
Keyless entry - adding presidentsdad 1987 - 1996 F150 & Larger F-Series Trucks 39 07-22-2016 08:16 AM
remote start with key-less entry question fordguy2236 1997 - 2003 F150 2 07-13-2013 09:49 PM
2000 f150 keyless entry wiring problem jeezjamie 1997 - 2003 F150 8 06-26-2012 07:00 AM
keypad keyless entry ogbobbyjohnson 1997 - 2003 F150 1 02-11-2012 09:47 PM
Keyless entry 2000 F350 2Wise4aGM 1999 to 2016 Super Duty 10 09-19-2010 04:12 PM
Tags
2001, 2002, code, entry, explorer, find, ford, keyless, keylessentry2001fordexplorersport, passcode, program, reset, set, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
