Installing an amp - how to get power wire through the firewall? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-14-2012, 04:17 PM
Ninja ZX 1000 Ninja ZX 1000 is offline
Ninja ZX 1000 is starting off with a positive reputation.
I'm installing an amp in my 97 B4000 and need to get a power wire from the battery to the extended cab portion. Any ideas/suggestions/proven methods of getting a 8ga power wire through the firewall without drilling? It looks like I *might* be able to share the hood latch release grommet but it maybe not. That's my main question. I'm also open to suggestions for mounting and grounding the amp. I do not want to mount it to the sub - vibrations = bad, plus it's one-stop shopping for potential thieves. Thanks.
Old 01-14-2012, 05:41 PM
grandmas77f150's Avatar
grandmas77f150 grandmas77f150 is offline
grandmas77f150 is gaining momentum as a positive member of FTE.
There are grommets in the floor pans you can use. Both my amps power wires went through the firewall grommet though, it's a tight fit, but it will work
Old 01-14-2012, 06:05 PM
Thanks. Errr, where are they, more or less?
Old 01-15-2012, 10:51 AM
When looking at your pedals, just to the right of the E brake on the firewall, there will be other wires going through there
Old 01-15-2012, 02:02 PM
crerar crerar is offline
crerar is starting off with a positive reputation.
Haven't used it for wiring, but when I was welding up my rockers (at the bottom of extended cab) I noticed there was an oval grommet near the bottom of the door pillar, towards the front of the extended cab section.
Old 01-16-2012, 02:34 PM
Thanks grandmas77f150, that did it.
Old 01-16-2012, 02:37 PM
Glad to help. I have a 4 gauge and 8 gauge power wires running through that grommet along with all my other cables
Old 01-16-2012, 02:41 PM
I can see daylight through it. Do you have any issues because it's not watertight?
Old 01-16-2012, 03:36 PM
I haven't had any yet, I had water come through the grommet on the floor pan though, I fixed it will silicone and bedliner
Where to run 4 AWG amp wire through firewall? AGrayson84 Expedition & Navigator 4 08-10-2016 11:19 PM
Need help with amp install in dash of 75 e150 Funke1 1968-2013 Full Size Vans 7 11-19-2014 08:09 AM
Subwoofer amp install- tips? Garrett248 Excursion - King of SUVs 26 07-18-2014 08:13 PM
Wiring an amp in 2000 excursion? mxracer41 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 8 05-26-2011 06:04 PM
f250 amp wiring question 2000ca250 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 5 08-10-2009 10:15 PM
Tags
2003, amp, battery, cable, excursion, f150, firewall, ford, pass, power, run, taurus, throug, truck, wire, wireing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
