steering wander problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-14-2012, 04:05 PM
jakif23 jakif23 is offline
jakif23 is starting off with a positive reputation.
I'm a new member so forgive me if I make mistakes. my 01 f-250 4x4 diesel has some steering wander Ive been fighting for a while. It feels like the front end is stiff and not returning right. All four spindle ball joints were replaced in the last year and a half. The tie rod ends seem to spin easily enough with a wrench but are not loose. MY question is how hard should it be to rotate the spindles with no tires or tie rods on them, wondering if my newer ball joints are too stiff and causing the wander or if everything checks out it my alighnment being a little off would cause poor return? Thanks for any help guys.
Old 01-14-2012, 09:20 PM
charbaugh's Avatar
charbaugh charbaugh is offline
charbaugh is gaining momentum as a positive member of FTE.
I noticed the same problem after I did my ball joints recently. Driving on the freeway was exhausting because I felt like I was constantly fighting to keep the old girl between the lines. If the tie rods and drag link do not have slack in them, then the problem is the steering box. To test the front tie rod and drag link you will need some help. Jack up the front end so both tires are off the ground. Turn the ignition to acc so the steering wheel is unlocked. Have your wife, girlfriend, significant other, etc turn the wheel from side to side while you are on the ground looking at the steering components. You are looking to see if there is any slop at any point. Ideally, if everything is tight enough, the moment the pitman arm starts to turn, the wheels should start to turn as well. If not, watch each joint carefully to find which one is bad.
If it is the box, the right fix is replacement, however you can adjust it to tighten up the steering. On the top of the box, there is a 5/8" (I think) nut with an allen head screw in thee middle. Loosen the nut and then tighten the allen head screw a little bit. Be careful to not tighten it too far, though, as you can cause further damage. I did this, and it fixed my wandering problem and the truck drives straight now. You should probably start with 1/8" turn and then take her for a drive. You can then tighten it another 1/8" if needed. Just a heads up on this, it can be akward getting the wrench in there and getting enough torque to loosen up the nut.
Old 01-14-2012, 09:32 PM
Benny76's Avatar
Benny76 Benny76 is offline
Benny76 is gaining momentum as a positive member of FTE.Benny76 is gaining momentum as a positive member of FTE.
Alignment could cause this if no parts are excessively worn. A lot of things could cause this, but if your caster is out then it won't self straighten. Such as a shopping cart. It has a lot of caster. So much that they are impossible to turn them sometimes and they "want" to go straight. If you have the opposite (no caster or negative even) then it will never want to go straight. Check for worn parts and replace as necessary then have it put on a machine. Was it aligned after the ball joints?
Old 01-14-2012, 09:45 PM
charbaugh's Avatar
Mine was. I had the allignment done the following weekend and had them check the tie rod ends, etc.
You are right about the allignment being a possibility as well. The thing is, when you fix worn out ball joints, you unmask other steering/front end issues.
Old 01-14-2012, 09:54 PM
Benny76's Avatar
This is very true. Ball joints don't move around anymore then other parts start getting more strain and start going or yeah, as you said everything feels loose at that point.
Old 01-15-2012, 12:24 AM
Thanks guys. I am replaceing the ball joints on one side cause it was really tight and the other side was nice and free. I have done the steering box, after two defective remans from auto value I went to a junk yard and got one out of a low mile excursion and it is pretty tight with no binding. If I can get some money saved up i want to some day put in a red head steering box. The joints are in now and it moves much better. I will schedule an alighnment this week, I was wondering about it but never thought about the caster. That makes alot of sense and is great advice. Thanks for all the help, I appreciate it. I'll update with results.
Old 01-15-2012, 08:21 AM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
jakif23 if you are going to do a steering box then go with a RED HEAD bow they are the best and will fix your problems.
Old 01-18-2012, 07:26 PM
results
Ok so finally my results......The ball joints in the left side were a cheaper brand so I replaced them with moog units. I checked all my tie rod ends and joints, all were solid but not too stiff. I took it in for an alighnment and found out that i did overtighten the new ball joints a little causing them to bind slightly (its possible that i caused the same problem on the other ones), but the shop was able to take them loose and reset them correctly which they said freed it up quite a bit. Finally with the alighnment done i gave the steering box a 1/4 turn and now have no binding and no slop. She steers like new again! Thanks guys for all the help!
Old 01-18-2012, 09:41 PM
Benny76's Avatar
Thanks for the update! It's amazing what an alignment will do. But how did the ball joints get "too tight"? No matter how much you tighten the ball joint to the knuckle it should still swivel in the ball joint right?
Old 01-18-2012, 10:18 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
"Cheap" ball joints could be the cause.
Old 01-18-2012, 11:07 PM
well they explained that if one joint gets pulled in farther than the other they are pulling against each other putting more pressure on them. Probably not a huge amount of friction for a good joint, but every little bit counts. They said proper way is to torque bottom(bigger) joint to spec and then tighten top one til the spindle starts to turn harder or you reach torque spec and stop there. Me, I just tightened them "good" and didnt torque them. Like usual it's the fine details that make the difference, never done learnin.
Old 01-18-2012, 11:15 PM
Chad149's Avatar
Chad149 Chad149 is online now
Deplorable
Chad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputation
Ball joints on a SFA can be put in "tight" if they are not pressed into the kn uckle equally or not torqued equally into the axle C (or poor manufacturing tolerance of said ball joint). The joint that is not fully tightened or pressed in will cause the nut on the other joint to try and pull the ball out of its socket to compensate, making it "tight".
Old 01-19-2012, 10:31 AM
1954oldred 1954oldred is offline
1954oldred is starting off with a positive reputation.
Quote:
So...what are the correct torque specs? I am doing mine this Saturday.
Old 01-19-2012, 09:11 PM
Benny76's Avatar
Great info! I love this website.
Old 06-17-2015, 05:27 AM
Kusich Kusich is offline
Kusich is starting off with a positive reputation.
U joints
Quote:
I had a similar problem with my 2004 f250 crew cab. When I turned the wheel and let go it wouldn't return to zero, and it would drift on the road and jerk side to side real hard and fast. So I jacked it up and took my tie rod off. then I used a big screwdriver and put it threw the u joint and rotated it so the yoke was straight up and down (like a plus sign, not an x) then I turned the tire both ways to full extent. It pretty much went where ever it wanted to and and was loose. I then rotated the u joint 90 degrees so the other axis of the yoke is up and down, and repeated the last step. This time it was a little harder to turn the wheel and it didn't move around freely. This meant that the the Bearings on this axis of the u joint was bad I Replaced them and the problem was solved. It increased the handling dramatically and was easier to turn than it was for the last 20,000 miles when I didn't notice any problem at all. And u joints are easy to change and cost about $30. Im only 18 and I had the whole thing tore apart, fixed, and reassembled in 3 hours
wandering Bird-Dog 250 1987 - 1996 F150 & Larger F-Series Trucks 4 09-28-2015 08:22 AM
DJM Tie Rod Relocater =SAFETY WARNING= overlandexpress 1961 - 1966 F-100 & Larger F-Series Trucks 9 02-15-2014 11:41 AM
Steering Stiff---Ball Joints Too Tight???? jeeptroll 1999 to 2016 Super Duty 4 05-08-2007 10:20 PM
wander, alignment, tires, steering box..... jeffdoerr 1999 - 2003 7.3L Power Stroke Diesel 12 04-22-2007 07:30 PM
Steering wanders/steering pump issues sfd4 Excursion - King of SUVs 13 01-09-2006 08:23 PM
Tags
ball, caused, duty, econoline, escape, f250, f550, fixed, ford, joints, stearing, steering, super, wander, wandering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
