Cruise Control blowing fuse - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-14-2012, 02:16 PM
bowler300623 bowler300623 is offline
bowler300623 is starting off with a positive reputation.
I have a '01 F250 V10 2wd. I keep blowing a fuse for the cruise and brake light circuit. The fuse blows immediately when inserted. What could be causing this.
Old 01-14-2012, 07:17 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
A chafed wire in the steering column could cause both of those issues.
Old 01-14-2012, 10:14 PM
xd2200 xd2200 is offline
xd2200 is starting off with a positive reputation.
Bad switch on master cylinder is very common issue on this vintage SD.
Old 01-15-2012, 02:45 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
It depends on the fuse. Please identify it specifically by its fuse #.
Did you have the speed control recall performed?
Old 01-16-2012, 01:08 PM
I just found out about the recall when I was researching the issue from this site. I will get the recall corrected either today or tomorrow. If this does not fix the problem, where else would you suggest to look?
Old 01-16-2012, 01:12 PM
The fuse information is:
#13 20A
Stop Lamps, Center High-mount Stop
Lamp, Trailer Tow Stop Lamp, Speed
Control
Old 01-23-2012, 02:16 PM
The speed control recall is corrected now. I am still having the same issues. I had to replace the plug to a ABS lead on the front left tire due to damage from a blowout. I did not see any damage to the sensor. Can the sensor be tested for continuity?
Old 01-23-2012, 03:33 PM
bpounds's Avatar
2 bit Californian
#13 20A
Control
If that fuse blows as soon as you insert a new one, then that list is of components is where you want to start. You have a dead short. It could simply be a bad lamp holder in any one of those. It could even be a bad bulb (rare). Start unplugging lamp fixtures until you find the one that is shorted. A corroded lamp fixture commonly causes shorts. Could also be a short in the trailer plug. Could be a short in the steering column. Wires for those functions go through the steering column, because of the turn signals. We can't tell you where the short is. You'll have to either ohm out each fixture, or use a process of elimination.
This should be easy to find, because it is a dead short, right? Not intermittent, which are a bitch to find.
Old 01-23-2012, 03:41 PM
Thanks! I will start checking one component at a time.
Found the Problem of Cruise "ON" button blowing the horn, & plugging in the gnd blows the fuse.. reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 05-18-2016 06:51 PM
Push Horn pad (with cruise) blow fuse.... reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-11-2016 10:26 PM
Brake position switch Plowboy34 Ranger & B-Series 13 12-05-2013 05:37 PM
horn fuse keeps blowing 1999 eeplorer v8 chaserboy Explorer, Sport Trac, Mountaineer & Aviator 1 02-21-2011 10:31 PM
Climate control, Cruise control and backup lamps fuse keeps blowing bfaulkner 1997 - 2003 F150 7 01-17-2011 01:39 PM
Tags
1999, 2008, 64, 96, 99, control, cruise, duty, f250, fix, ford, fte, fuse, speed, super, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
