Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 01-14-2012, 10:47 AM
kmonty2's Avatar
kmonty2 kmonty2 is offline
2011 Ford F-250
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
kmonty
Heat slow to get warm
This winter I have noticed that the heat is taking longer to get warm then I remember last year. Anyone else having the problem. Now I am only driving about 4 miles to work but last winter I had to turn the heat down because it was to hot. Now I have it on high all the way to work. Nothing has changed from last year. Truck still sits outside and I use the block heater when it's going to be lower then 35 degrees. It does get hot but takes a lot longer then before. Also I think the blower on this truck is way to small and does not blow enough air.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
  #2 (permalink)
Old 01-14-2012, 02:57 PM
8iron 8iron is offline
2011 Ford F-250
8iron is starting off with a positive reputation.
Just a couple WAGs... If you think it's an airflow issue maybe the cabin filters are glogged? Was it a dusty summer? Do you have anything behind the rear seats/ (I think that's where the filters are). OR is the water/coolant getting up to temp the same as last year? I know it's hard to tell from the guage but maybe your TStat is stuck open?
Good luck
__________________
2011 F250 6.2l Lariat FX4
  #3 (permalink)
Old 01-14-2012, 03:08 PM
kmonty2's Avatar
2011 Ford F-250
kmonty
I will check the filters. At the campground this summer it was very dusty most of the time and that very well could be a issue.
__________________
Kevin
Tags
62, f150, f250, ford, heat, heater, hot, long, sale, slow, takes, time, truck, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
