55 ford 5 speed direct transmission help
Okay so my dad and i are restoring my Grandpas old 55 and we have swapped in a 292 V8 with a 5 speed direct tranny and have run into some problems. My put the gear shift into the transmission and moved it into 1st and now it wont go into any gears. I just want to know if anyone can help me understand what went wrong and how we can get it operational. I really need some help please!!
What was the donor of the engine? What was the donor of the transmission (if different)?
Was the trans and engine mated before - did they both come out of the same donor together?
How much modification did you do - switch to hanging pedals, etc or just hook up the clutch linkage and go... did you have to modify the clutch linkage a ton?
What model of 5 sp - there is almost none that I know of that are direct in the top gear?... I'd love to add it to my trans database/article.
your story jives with a little research i can do at the moment, sounds like you have a clark 5 speed. could be od or direct... i am on my phone at the moment so research is a pita... here's a thread to get you started / would google around for clark 5 speed clutch schematic.
https://www.ford-trucks.com/forums/5...ive-clark.html
Welcome to the forum. My '56 shop manual shows a light duty and a heavy duty five speed direct drive transmission. Pictures indicate they have three shift forks. Your second sentence is unclear to me but if there is any chance the top has been off the tranny I would pull the top back off and make sure the forks are in the shift collars and you can position the slides and the gears on their respective shafts. Be careful of the detent ***** and springs.
brandonrmeredith
05-17-2015 09:38 PM
jade79
08-14-2011 10:42 PM
branpollard
03-03-2005 01:32 PM
