1969 f100 pink resistor wire help
man, this thread has turned into a mess.
to the guy with the '83 and fuel tank issue...are you sure there's supposed to be a resistance wire there? that wouldn't make much sense.
to the guy with the black wire...measure your voltage at the coil with the truck running. there's no other way to know.
both of you might be better off creating separate threads.
49" long / Color coded red with green stripes / 1.30-1.40 ohms resistance / #16 gauge wire.
1977/91 F100/350, Bronco & Econoline.
There is no such thing as a black resistor wire.
mine is/was pink and black, far as I know. but the problem is I'm getting power/resistance correct on the wire I'm just not getting it in the actual relay if that makes Any sense... anyway thanks
I found this thread because I believe I need to replace the resistor wire between my fuel pump relay and tank selector relay, it's not giving me any resistance at all nor is it getting power when it should and as a result i believe my truck won't stay running. It's a 1983 f250 with a 460 and duel tanks, and a "hot fuel" option. my question is, how do I replace that resistor wire? Where do I find specifications? I know it needs to stay the same exactly to work correctly.
correct me if i've misread your question-
you're asking about an electric fuel pump relay on an '83...but this is a thread in the 67-72 forum about the ignition coil resistance wire...we're talking about completely different things.
i'm all for trying to help, but this is just the wrong spot. none of us have OEM electric pumps, fuel relays- any of that stuff.
there's a lot of user activity in the 80-86 forum- i'm certain if you post your question there, those guys will absolutely be able to help you out.
If your running full voltage to a stock coil you can burn it up quick. Should be getting 8-9 volts at coil with correct resistor. Might be worth checking before you get stuck somewhere.
70T351W
Electrical Systems/Wiring
05-01-2006 11:21 PM
mikenusaf
04-27-2005 10:53 PM
