Fuel gauge not working. - Ford Truck Enthusiasts Forums
Old 01-13-2012, 10:41 PM
Highboy74's Avatar
Highboy74 Highboy74 is offline
Highboy74 is starting off with a positive reputation.
In my 1974 F250 4x4 (highboy) the fuel gauge is not working. I replaced the sending unit and nothing. I checked to see if there is power when the ignition is switched on and acc and there is. What else could be the problem? Any thoughts?
Old 01-13-2012, 10:53 PM
76Hauler's Avatar
76Hauler 76Hauler is offline
76Hauler is gaining momentum as a positive member of FTE.76Hauler is gaining momentum as a positive member of FTE.
do you have dual tanks?
Old 01-13-2012, 11:05 PM
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
I was having trouble with all the gauges on my 75 when I first bought it. Spent days chasing wires and reviewing schematics... The root of my issues boiled down to the schematics not necessarily being 100% accurate.
The trouble as it turned out was with the ground. I am not the best person to explain this but basically instrument clusters work off the ground versus the power. And there are two grounds, a general and one with the resistance wire; once I determined where each was and where they went the cluster lit up lit a xmas tree.
I even went so far as to replace the entire cluster but the same issues were present; I later found out that the clusters don't often go out. Its usually the wiring going to the cluster that has the issues.
Old 01-13-2012, 11:35 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Disconect the wire that goes to the sending unit and ground it. If the gauge goes to full then the problem is either the new sending unit or the ground. If the gauge still reads empty with the wire grounded, the problem is either the gauge itself or the wiring.
Old 01-13-2012, 11:49 PM
Highboy74's Avatar
Okay, I took the wire on the top of the sending unit and "grounded" it. I held it one of the bolts that holds the sending unit in place on the tank and after some sparks and smoke, the gauge never moved. The orange wire got very hot as I held it to ground it out. Do I need to remove the actual ground wire to conduct the test or leave it there? I left it in its place and like I said the main wire to the sending unit got very hot and the gauge never moved.
Old 01-13-2012, 11:51 PM
Highboy74's Avatar
If the gauge is bad, who makes replacement gauges?
Evan's F250's Avatar
Evan's F250 Evan's F250 is offline
Evan's F250 is starting off with a positive reputation.
I had to pull my gauge cluster out of mine and clean the copper circuit board up with some fine sandpaper. take the piece off that is for the gas gauge, clean it and under it..go all around the whole circuit board, taking every bulb out and cleaning around it, along with takin off the little nuts and cleaning under them as well.
Old 01-13-2012, 11:53 PM
Highboy74's Avatar
I did clean the copper for all the lights, but no the gauges. I'll try that. Give me about 30 min.
Old 01-14-2012, 12:02 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Here's 22 of the puppies NOS (New Old Stock).
D3TZ-9280-A .. Instrument Cluster Fuel Gauge-Use with Leaded Fuel / Obsolete
Applications: 1973/74 F100/350 / 1975/76 & 1977 F150/350 before serial number O80,001 / 1975/76 & 1977 Econoline before serial number O80,001.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
ERICSON FORD in Loup City NE has ONE = 308-745-0667.
TISON MOTOR CO. in Estill SC has ONE = 803-625-2551.
PARTS INTERNATIONAL in Farmers Branch TX has FOUR = 888-727-0418.
KINSEL L/M in Beaumont TX has FOUR = 800-816-2894.
CARPENTER NOS OBSOLETE PARTS in Concord NC has FIVE = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has SIX = 800-543-4959.
Old 01-14-2012, 12:03 AM
crazy96863's Avatar
Be sure to check your resistor wire for breaks or disconnects. Also be careful arcing on a fuel tank.
Old 01-14-2012, 12:04 AM
ok............
Old 01-14-2012, 12:09 AM
crazy96863's Avatar
I saw a setup which replaced the entire cluster and trim all the way over to the climate control and radio with a piece of aluminum with cutouts for the accessories; the gauges were all aftermarket... Autometer I believe. If I wasnt trying to stay closer to the original look i would do this. It was really nice and clean plus durable.
Old 01-14-2012, 12:14 AM
Highboy74's Avatar
The resister wire is the "hot" wire or in my case the orange wire, right?
Old 01-14-2012, 12:15 AM
Highboy74's Avatar
@ NumberDummy. Nobody has anymore gauges or there are 22 available?
Old 01-14-2012, 12:19 AM
Highboy74's Avatar
I cleaned the contact area for the gauge on the back of the cluster and still no movement.
Project: 1971 F250 2wd becomes 4wd Zazoos 1967 - 1972 F-100 & Larger F-Series Trucks 96 12-05-2015 02:38 PM
'Highboy' question southpole 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-16-2014 09:53 PM
Fuel Tank Options on a Highboy jackslater 1967 - 1972 F-100 & Larger F-Series Trucks 2 07-11-2011 10:42 PM
Where do you put your gauges? adamtheman16 1973 - 1979 F-100 & Larger F-Series Trucks 64 09-02-2010 02:58 PM
highboy manual to automatic oldblue31 Clutch, Transmission, Differential, Axle & Transfer Case 2 03-14-2006 12:02 AM
Tags
1974, 2002, 2009, 54, f250, fuel, gage, gas, gauge, lincolin, lincoln, mkx, navigator, problem, replacement, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
