No power to fuel pump - Ford Truck Enthusiasts Forums
Old 01-13-2012, 10:29 PM
rangergirl94's Avatar
rangergirl94 rangergirl94 is offline
rangergirl94 is starting off with a positive reputation.
Ive tried searching but got nothing ive got no power to my fuel pump on 92 f150 300 i6 I tried to hot wire it but it dumps fuel out the exhaust then dies?
Old 01-13-2012, 10:55 PM
SCRebel's Avatar
SCRebel SCRebel is offline
SCRebel is starting off with a positive reputation.
Use a test light, or a voltmeter and see if voltage is getting to the injectors. If there is no voltage going to the injectors I would say the computer is toast.
I had a 87 F150 with a 4.9 EFI. The computer was fried, the computer wasn't grounding out the injector relays or fuel pump relay, so power wasn't getting to the fuel pump or the injectors.
Old 01-14-2012, 12:44 AM
Is it ok if I just hot wire the positive to a fuse that comes on with the key
Old 01-14-2012, 01:27 AM
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
I second that! I have a 94 Ranger that kept giving me the old "ground to fuel pump" code, and would not keep the fuel pumping running. It would act as if it ran out of fuel or vapor locked. I tried bypassing the harness to the pump and it worked, momentarily and the computer fought my bypass.
Old 01-14-2012, 09:17 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Well there is no such items as the "injector relays".
You have the PCM power relay but the computer has nothing to do with picking (grounding) that relay or sending power to the injectors.
The PCM power relay coil has one side permanently hooked to ground and the other side is powered by the Ignition switch.
The PCM power relay does send power to all of the injectors, fuel pump relay coil and other solenoids.
You can unhook the computer and take it out of the truck and turn on the key and still have power to all of the injectors and the fuel pump relay.
The 1992 is the same as the 1993 wiring below.
Old 01-14-2012, 09:30 AM
subford's Avatar
Quote:
Sounds like all of you injectors ground wire is shorted to ground.
It could be a bad computer.
Yes you can bypass the Ignition switch for a test. Do you have open (bad) fuses?
Old 01-14-2012, 09:35 AM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Have you checked the inertia switch? Just throwing that out there. I always overlook the easy stuff
Old 01-14-2012, 09:56 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
How 'bout the relay?
Old 01-14-2012, 10:10 AM
4601ton 4601ton is offline
4601ton is starting off with a positive reputation.
Hmm...this computer thing would make sense...my truck also gives the fuel pump circuit open, EEC processor to motor ground...never knew if that ground was the EEC itself or not. My truck has a surging idle, but always runs fine...
And Rangergirl, sorry to hijack. Seems to me that however you jumped it before, it bypassed the EEC (possibly because it's fried) and made all the injectors fire at the same time, instead of in sequence...causing it to ultimately dump fuel out the exhaust, when it had nowhere else to go. If my theory is correct and it would have kept running, it would have hydro-locked the engine. Good luck, I'll be keeping an eye on this to see what fixes it...
Old 01-14-2012, 04:07 PM
Can I change the fuel pressure regulater without pulling the intake manifold
Old 01-14-2012, 05:35 PM
SCRebel's Avatar
Yes you can.
Old 01-14-2012, 05:38 PM
5Rangers's Avatar
5Rangers 5Rangers is offline
5Rangers is starting off with a positive reputation.
If you want to fix the truck , listen to Subford.
Old 01-14-2012, 05:59 PM
I hot wired the pump to a fuse thatsl comes on with the key it runs but dumps gas out the exhaust? What would cause that
Old 01-14-2012, 06:03 PM
SCRebel's Avatar
I think your computer is not telling the injectors when to open or close. so they are probably, open. And you hot wiring the fuel pump, the fuel pump is constantly running. This will fill the combustion chamber with fuel and the fuel will pour out the exhaust and get into the oil.
I believe you need another EEC.
Old 01-14-2012, 06:16 PM
5Rangers's Avatar
Maybe verify this is so by pulling an injector and see if its dumping. If so focus on that circuit.
2001 F-150 fuel pump won't run when cold 1963f100 1997 - 2003 F150 10 12-16-2016 09:38 PM
87 F250 Fuel delivery trouble sapman92 1987 - 1996 F150 & Larger F-Series Trucks 0 09-07-2014 03:55 PM
not getting power to fuel pump 79rngr 1997 - 2003 F150 2 06-26-2014 06:10 AM
no power to fuel pump 79rngr 1997 - 2003 F150 6 06-25-2014 11:14 PM
not getting any power to my fuel pump 95blackf-150 1987 - 1996 F150 & Larger F-Series Trucks 16 12-17-2011 01:46 PM
Tags
1993, 2004, 50, 95, eec, explorer, f150, ford, fuel, injectors, pcm, power, pump, relay, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
